Log splitter help
/ Log splitter help #1
jdhacker
Ky
Cub 3240 Poulan pro graden tractor
New guy here, I traded for a Brave log splitter. Made in 1987 I think, It dosent look like it was used much. It had a couple of problems, It looked like it had been wrecked. It looked like something had went through where the governer plate is and tore all of that out. So I replaced the governer parts, the carb was stoped up. So I cleaned and put a new kit in it. The 5 hp briggs will now start on the first pull. So I start the splitter nothing, I take the pump off, the lovejoy was pushed back on the moter shaft and the set screw was loose. The bushing was missing, so I got the bushing put it back together. Started the ram move smooth forward and backward. I done that several times. Put a piece of wood on it, wont split, it does pull the motor down a small amount, and makes a small place in the wood. But it act's like its not kicking down in high pressure. I know nothing about hydraulics. And help is greatly appreciated.
/ Log splitter help #2
The cyl can only develop pressure if the pump is doing it's job, and the cyl or valve is not leaking/bypassing.
If you install a hyd gage, you can use it to troubleshoot the hyd system.
As you operate the valve, you can see any pressure developed by the cyl.
Can you verify that the pump is turning at the same rpm as the engine?
Can you take the pump out hose and run it into a bucket or the tank and see if the GPM's are correct.
/ Log splitter help
Update this thing looks like it never split wood. Any way what I did was adjust the pressure on the pump until it would almost kill the motor. Then put a piece of 16 in twisted hickory in it and it split no problems. I had to turn the adjustment two and a half full turns. I dont understand that. But seems all is well.
/ Log splitter help #4
Don't feel bad. I bought an American splitter from a guy who didn't use it much and I suspect didn't actually know which was the business end of a screw driver. The detent kick off never worked on it and one day I got curious (and pissed) and traced the hydraulic hoses and fluid flow...... turned out the hoses were not installed on the splitter correctly. 5 minutes of simple wrench work, set the detent pressure and Viola......... has been working perfectly for a hundred + cords of firewood.
/ Log splitter help #5
Hello all, new guy here......log splitter probs also wish/hope mine turn out like yours but i need some help before i DIVE in. Heres my dilemma.....
I have a 1986 DUERR 20 ton splitter (my dad purchased new) has not worked properly for a long time im told. I put a 5000 psi guage on and a new harbor freight 6.5 hp engine and it intermittly went to 2500/2800 psi when I bottomed the piston out, now it never goes above 550/600 psi (1st stage) I have pump and valve in hand on table, pump is a haldex/concentric 1012 (todays # is 1001689) valve is a Prince ls 3000-1, there are no #'s on cylinder at all. I planned on taking pump apart as I feel this is my prob. should I? or valve or both? Im willing to buy what I need but i dont wanna be a parts replacer with not knowing for sure what the prob. is. Im here for any help or a direction to head in, by the way I drained and strained/filtered the oil and cleaned tank spotless with gas/air (I believe oil is fairly new and I replaced filter prior to all this (10 micron)) OK fellas hit me up, I gotta lotta wood to split and a day off lol :eek:
/ Log splitter help
IF you run the ram half way out, is the fluid full. also is the vent working, Also look at the hoses, make sure none of them is collapsing.
/ Log splitter help #7
I think we have the same splitter made in Washington?
Mine has been problem free... and has not yet been stumped by anything I have thrown at it.
I have to confess to never changing the hydraulic oil or filter...
I was not able to find the company when I did a search so it might be out of business or changed names?
I'm sure it will do the job for you.
/ Log splitter help #8
Mine is orange, I've seen blue ones also, my engine is on the right, I've seen them mounted on the left also (from vertical operators position) and he's looooong out of business. Had prob with 1st one and he sent my dad a new one and never picked up the old one (sold that 1 after a few yrs, lol) He said he had a "lot" of bad pumps and thats why he shipped another complete splitter, in anycase the pump was replaced on the newer one also quite a few yrs. ago and I was told it never worked just rite (no body ever took the initiative to put a gauge on it either). So I'm trying to get it fixed correctly, I mean all ya got is an engine (mine is new, the old briggs was tired, fill the oil and check the gas lol, but she ran good) a pump, valve and cylinder. Hopefully I'll get some info shortly but in the mean time I think I'll start splitting the pump and look at it. HELP me out guys!!!!!
/ Log splitter help #9
The problem could be any number of things.
Cylinder, valve, relief valve,etc.
Before you tear that pump down, you need to provide some resistance to the pump flow, and this can be done by removing the extend hose and install a needle valve on the hose.
Have someone aim the needle valve output into a bucket or tank, and start the engine. Then slowly turn the needle valve in clockwise and look at the pressure gage. If the pump is good, the pressure will build as you turn the needle valve in. If you close the needle valve to far, the valve relief will go off. and lug the engine.
Next, check the cyl for bypassing by starting engine and extending the cyl. Then remove the retract hose from the cyl, and place in a bucket. Now, try to extend the cyl some more. If the cyl is bypassing, fluid will flow from the rod end port.
To check the valve, use the needle valve in one of the work ports. Place a hose from the needle valve in a bucket and activate lever, and turn the needle valve clock wise to close off the flow and watch the gage for pressure build up. If the valve can maintain pressure, you can figure the valve is good.
Check and or replace your return filter.
/ Log splitter help #10
Hi JJ----- At this point I have everything apart (off the machine, not opened up yet), but prior to this I had a gauge on the high pressure hose between the pump and the valve, when I push the ram against the wood or fully extend it the gauge reads 500/600 psi which is the limits of stage 1, it does not seem to want to go to stage 2 anymore. As far as you saying to put resistance against pump flow, aren't I doing basically the same thing? As far as the cylinder check, well, I got the info to do as you said after I had it all apart unfornunatly, also my valve is "hard mounted" to the cylinder with a nipple at the retract port rather than a hose, of course I can get a hose made up to bypass the nipple to preform this test, or can I check in reverse and retract fully and disconnect the extend hose?
I did go to a hydraulic shop and he watched the gauge and was fairly sure it was a pump issue, in my situation, being its all apart,would it make sense to "look" at the pump internally (I've been told the O-rings go bad) prior to putting it back together? (not that its that much to do) Also would you know where to get an exploded view view of this pump? I tried haldex directly and northern directly but got nowhere. (the time it took to do this is why its not in peices yet, lol) also can I used a ball valve for testing?
Thanks Jim
On second thought I'm putting it back together because it was really only in pieces to give the tank a good douche, spent to much time behind this screen and my mind went to muush :confused2:
/ Log splitter help #11
Glad it's"working"...what did you trade for it?...just curious...!
/ Log splitter help #12
Thanks Jim
You have bad advice..:confused2:... orings/seals will not bring back a worn out pump.......time for a new one if that's the issue, those log splitter pumps are throw-aways (the gear sets and housings wear out)
/ Log splitter help #13
Just make sure the valve has a 3000 psi pressure rating.
I posted a breakdown of that pump long ago, and don't remember where I found it.
/ Log splitter help #14
ok wdchyd.......good to know, thanks
J.J. yea they made it sound like it's part of the stealth bomber. A break down is "TOP SECRET" the best I found was a cross section of the pump on northerns website.
Talked to prince mfg about the valve, he told me those valves are "Bullet Proof"
So its all back together and gonna fire it up, check cylinder and so on, ill let ya know what i find out shortly
Thanks for everyones info do far!!!!!!!!!!
/ Log splitter help #15
WOW Think I got it!!!! fired it up and couldnt get but 200 psi on forward stroke, retracted it full and detent kicked out like it should, pushed handle and held it and got 2500 psi instantly! this tells me pump is good, piston is good----------it's gotta be that "bullet proof" valve !!!!!!!!!! correct????
/ Log splitter help
Ok guy's im back in need of help. I got the splitter going it's a brave with all the factory parts on it. But someone had messed with the splitter when I got it. The problem is it's not getting above 700lb of pressure, at 700 pounds it pulls the motor down and almost kills it. Its like it's not getting in to the high pressure side of the pump. This is the pump John Barnes 1001054
Also it's a 5hp briggs in good shape, and it's full of hydraulic fluid
/ Log splitter help #17
Somewhere on that pump is a check valve that is supposed to close when pump section 1 reaches the by-pass point and starts circulating oil internally. If that check valve sticks open the flow under pressure from pump section 2 will take path of least resistance and flow back into section 1 and recirculate inside the pump. Different brands of pumps may have different style of relief and check valves but theory of operation is same.
Here is an old thread I found post #2 gives a good breakdown of the Haldex pump.
http://www.tractorbynet.com/forums/hydraulics/110334-adjusting-unloading-2-stage-log.html
/ Log splitter help #18
Let me try to explain how a 2-stage pump works. Unlike a mechanical transmision it does not shift gears or down shift.
There are 2 pumps in one housing. A small pump which sends fluid to the system at all times. The second pump is much larger and has a by-pass built into it. When pressure is low both pumps send fluid to the system. When pressure increases to a preset adjustable pressure ( 600-900psi ) the by-pass on the large pump opens sending fluid back to the suction side and a check valve closes between the large and small pumps discharges. The small pump requires only about 1/3 the hp. to reach the maximun pressure as would be needed to operate both pumps.
If the engine is stalling at 700psi then this is a indication that the by-pass is not openning.
/ Log splitter help
Well I took the pump apart today, the high pressure gear set was broke. Picked up a new pump and will install it tomorrow. Thanks for all the help guys.
/ Log splitter help #20
Good or Bad... nice to know you identified the cause.
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
