Max landplane for ATV?
/ Max landplane for ATV?
Do you have a garden tractor you can pull it with?
I'll have a ride on mower in the spring, but nothing substantial... just a crappy MTD
The Jeep has the power, traction, and weight... it's just big and not very manuverable.
/ Max landplane for ATV? #22
Build it with a 2" coupler on it then you can pull it with anything that has a trailer hitch. The Traker may be the best since it is small.
/ Max landplane for ATV? #23
Here is a 4 ft landplane I built for my garden tractor, I suspect you could put chains on the top front of the skids with a tow ring and pull it with one of your vehicles. This is a good match for a scut sized tractor. Without the need for the 3ph it should be a quick and easy build.
/ Max landplane for ATV? #26
I have a 4' box blade that I use behind my honda foreman. I mainly use it for finish grade in yards and over trenches. It works great as I put the wheels behind it to raise an lower/set grade it but if I get much of a bite it will stop the atv.
For what your doing 4' would be max. Set the blade straight and lay it back at a angle so the material will ride over it.
