PST vs HST
   / PST vs HST #11
We have geared and HST,much prefer the HST for all of our tasks.Safer for less experienced operators for sure.
   / PST vs HST #12
At one point I could not understand the draw to HST "trannies" So I tried two. A Kubota guy brought one up for me to try on my land. Hated the pedal as it was simply pivoted in the middle. Then tried a Mahindra 3016. I felt it was underpowered and rpms had to be kept up if you wanted to do work. Now granted this is not a worldly experience on hst tractors. I'm thinking a lot may have to do with tractor sizes bigger being better for hst but as it stood, I stuck with the shuttle shift. I like the idea of maintaining the quiet and peace of the woods being able to do work at almost idle and I have never found that I could not finesse a geared tractor in close quarters. As I use my tractor for snow plowing and skidding heavy stems and with 28 hp, I'm glad I stuck with the geared
   / PST vs HST #13
A power shuttle is lot different than a plane standard transmission. I have had a PowerShuttle for years and love it.
   / PST vs HST #14
If you consider not having to use the clutch to change direction, Otherwise you still have to find a gear and place it there. They are certainly different in construction where synchronizers are replaced with either clutches or planetary gears.
   / PST vs HST #15
I think both are more than acceptable for most operations. I don't get too hung up on the different transmissions. A PST doesn't need to be clutched so it is plenty maneuverable. If I have a ton of altering movements, I use a HST as they have finer control. If it is a normal balance of work, a PST is just fine. The PST is often better without the high rpm and whine. Maybe it is just me, but the whine wears on me, even with full ear protection.
   / PST vs HST #16
I have used both. There are definitely times when a shuttle shift will outshine HST, and like has already been mentioned, those times include plowing, mowing, brush hogging, and other ground engaging tasks. I do feel that shuttle shift puts more power to the ground than HST, hands down.
But for the convenience of operation, and the lack of fatigue associated with shifting, HST is the winner hands down when it comes to overall usability.
As for the whine, I noticed it often on my previous tractor, a 23 HP Kioti CK20. However, on my current tractor, I ONLY notice it if I'm in Hi range and bogging down the hydraulics.
Doesn't bother me much tho.
   / PST vs HST #17
If I was doing a bunch of ground engagement work and rear end work such as bushhogging and disc, box blade and so on and some loader work I would go with a PST. Now if I was on the tractor from morning till dusk working the loader I would buy a HST in a heart beat. I often Have customers who come in asking for a HST but Not a fan of the HST price. to which is when I ask them what they are using it for. I will say if I were to go but a tractor today I would buy the PST for the simple fact of ease of operation of all types of jobs, also do to long term cost of repairs many years down the road. I love the set up of the Mahindra 35 series PST and wouldn't trade it for a HST. Personal opinion
   / PST vs HST #18
This also only my personal opinion. When bush hogging HST beats any kind of mechanical trany. The exception might be only if the mowed area is free of obstacles and the tractor has enough power reserve to run the mower in any grass. Here is why. On HST the PTO speed and tractor speed are not tied together. So going around obstacles doesn't require shifting or shifting in reverse. If the tractor has only small power reserve and mower starts bogging the engine (like on most SCUT, CUT tractors) it is easy to slow down or even stop until the grass is discharged and then continue at whatever speed.
   / PST vs HST #19
RIT, you got it exactly. For mowing on uneven terrain, or uneven grass/brush height, the HST allows you to vary your speed as needed. Gear drive usually means selecting a gear for the most difficult part, and loafing along for the rest. I have always been able to bushog more acres per hour with an HST. In the woods, an HST might save your life, if you run into a hidden obstacle or run into a stout low-hanging branch. Just lift your foot and it stops. You don't always have enough time to find the clutch in an emergency.
   / PST vs HST #20
I had a Yanmar 4220 with powershift and loved it. It had 4 speeds, N and R in 3 ranges. I never found anything that would stall it so bad that I couldn't downshift to a lower gear. I selected the range for average load so that I was in gear 3 and then could shift to 4 for light areas but give me 2 lower gears for heavy loads. I really liked it but HST is pretty close in performance and everything can be done with your foot, leaving both hands for steering, FEL operation or hydraulics. I don't think one would notice the loss of engine power in anything but the lowest powered units. One just has to get a bit more engine power to give you the edge in performance. When properly used, HST users wont notice the loss. I can actually load my FEL bucket when in loose dirt with it in High range and not stall the engine by just backing off the HST pedal as I move into the dirt. It wont spin the tires like it will in M range but for transporting material from a spoils pile to a distant area, being able to do that without shifting ranges is great.
Also I don't have to run WOT for the HST to work. It works well at 1500 RPM for all but the toughest application. For backhoe use, about 2000 RPM works good for speed and reduced noise-2600 is full throttle and really increases noise for that last 600 RPM.
For CUT tractors, I wouldn't buy anything but an HST. I do have shuttle shift geared utility tractor but it will wear out a leg in FEL F/R action in short time. For bush hogging, disking or even tilling it is fine. I can get as slow as I need to with the creeper gear and 20F/20R. transmission
2021 VOLVO VN SERIES DAY CAB (A55745)
2021 VOLVO VN...
2011 COMPTANK ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK ACID...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
Black Plastic Mailbox and Post Kit (A54865)
Black Plastic...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
