Snow JD 1025 W/54"SNOW BLOWER SKID MARKS
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #11
Hey James, Glad you found an easy solution at the dealers. Check that caps lock key often, It seems to be coming back on quite often.
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #12
TALKED TO JOHN DEERE DEALER TODAY. JOHN DEERE HAS A PLASTIC SHOE FOR THE SNOW BLOWER- M157831, THAT SELLS FOR $18+ FOR EACH. I AM NOT SURE HOW THEY WILL HOLD UP BUT IF IT SOLVES THE PROBLEM....
Thanks I order the plastic sheet for 20 from amazon. Will cut the sheet and make the running as described..
Will keep you pistes on how it works
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #13
You had the option to order them all cut to size from the supplier. But if you have the means to slice them up then no issue. Enough for 10 sets should be good for years of fun snowblowing...........!
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #14
Made the runners this weekend , cut the plastic on my miter box and then drilled for screws as Genesusie suggested ..Road tested on driveway this weekend and no marks.. Genesusie excellent, i made an extra pair just to have them. Tomorrow we may get 5" of snow in CT, ready to test the new blower and 1025r. Ballast ready to be filled with sand … Unfortunately my cab and heater are not arriving until Jan 1st, guess i will need to rough it for now :>
Again thanks for the advice, it was easy and kinda fun to build the skids
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #15
Pictures would be nice! :)
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #16
Pictures of the snowblower foot skid
Blower handled 5" of wet snow today with skidder. Hope I attached picture correctly, 1st time
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #17
looks good.
glad this solved your problem!
2013 MACK CHU613 (A55745)
2013 MACK CHU613...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
Towable Orchard Sprayer (A55851)
Towable Orchard...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
