Carry All Mainer Version
/ Carry All Mainer Version #1
motocephalic
Maine
2013 Kubota L3200DT /FEL
I finally got to make a carry all that I have been hemming all about. I ended up using wood for the removable sides, 1.5 tubing for the rear stakes and 2X10 for the body. Overall I think it will work out well, mostly using it for wood both cut and 4' length, thus the stakes in the back. It weighs more than I expected, and full of wood I suspect it will be near capacity. I can feel it 1/2 loaded already. I have about 300.00 dollars into it and about 1.5 days of work. I had a great time doing it, which made it a deal for me, except for it being so cold. I am not getting used to this cold in Maine. It will be my first in 25 years. I went through 2 propane tanks trying to keep warm.
/ Carry All Mainer Version #2
Not that I'm insulted but why did you call it "Mainer Version" :confused:
my own little twist using metal in the corners, kinda rustic design and over engineered.
/ Carry All Mainer Version #4
My Dad would have said "You can get a good jag of wood on there !". Esp. with hardwood, that will add up.
Nice build quality, and will be a good ballast for the FEL, if you don't have another one already.
Cold - layer up, and buy really good long johns (top and bottom) to start. Eddie Bauer is my favourite. Easy for time to fly on a build project - remember to keep eating healthy snacks as you work - everybody burns more calories in the Cold. I also typically wear a good winter vest, under my coat.
Rgds, D.
/ Carry All Mainer Version #5
A Mainer version should look more like this,, 002.JPG and if you look in the background you will see a blue tarp covering the end of a building,,
/ Carry All Mainer Version #6
Well done. I may be building a box for my carry all today, if, I get some other chores finished. I like the removeable sides idea. I may borrow that from you.
/ Carry All Mainer Version #7
I agree, it appears to be much too well constructed to be made by a local. Try it again but only put $30 into it and let us know how it comes out. You can use materials from the dump.
/ Carry All Mainer Version #8
Yup, MUCH too fancy. Ya gotta use a couple of old pallets, bed iron, chicken wire, some duct tape and at least one Maine State Flag (blue tarp)
that's a hoot, never realized the state flag colors
I've been away for a long time, I've got to relearn a few things yet.
you mean like this one?
/ Carry All Mainer Version #12
Well, Moto, that certainly has possibilities! :D
Added bobbles to the carry all, and then tried it out to see if any of it worked.
/ Carry All Mainer Version #15
Any more details of the construction? What did you start with for a Carry-All? Yours is built with higher quality than most 'Mainer Versions' that I have seen. Dang... you just created another project for my ever growing list.
PHPaul said:
AKA Downeast Roofing...:D
Plenty of 'Downeast Roofing' here in the Mid-Coast as well.
I bought the frame for the carry all from TSC in Scarborough, and them added 2X10's to the frame, I made the sides out of PT decking bolted to PT 2x4 reinforced with metal corners, 2 removable stakes for the rear to hold 4 foot length wood, added to chain saw cradle with file holders and axe/maul holder. I've used it for 2 days and it's working out to be quite handy. Not quite heavy enough of a ballast for the plow, but I'm sure it weights nearly 400 pounds.
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A62129)
2016 JLG ECOLIFT...
30 Yard Dumper (A61166)
30 Yard Dumper...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
King Cutter Rotary Cutter (A63116)
King Cutter Rotary...
