Snow JD 1025 W/54"SNOW BLOWER SKID MARKS
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #1
JAMES KELLEY
Member
MEADVILLE, PA
JD1025
MY NEW UNIT IS LEAVING SKID MARKS ON BLACKTOP DRIVEWAYS. HAS ANYONE ELSE EXPERIENCED AND/ OR TRIED SOMETHING DIFFERENT TO ELIMINATE OR SOLVE THIS PROBLEM?
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #2
James,
I lined the skids with high density plastic. Shaped them to match the skids, are 1/2" thick x 2 1/2" wide x 6" long. They slide easy on black top driveway and no marks.
THANKS FOR YOUR POST. WAS THIS A D-I-Y JOB AS I AM NOT FAMILIAR WORKING WITH PLASTICS? DID YOU JUST COAT THE EXISTING SKIDS OR... USE THEM AS A MOLD TO MAKE AN ALL PLASTIC SKID? ARE THE PRODUCTS YOU USED AVALIABLE IN A HARDWARE STORE OR BUILDING CENTER?
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #4
Did you ever get a solution? I was thinking to call Robalon to see if they have a replacement for the metal feet. I want to avoid a cramping the driveway , it was just paved and cost big bucks.....
I have the 1025r with 47" snowblower .....
JUST ONE REPLY SO FAR - HOPING TO GET MORE INFO FROM A MEMBER THAT USED HIGH-DENSITY PLASTIC. I HAD A 42" BLOWER ON A GT 235 TRACTOR AND IT DID NOT LEAVE MARKS - THOUGH IT PROBABLY WEIGHED 1/2 OF THIS BLOWER. NOT SURE IF WIDER SKIDS WOULD SOLVE THE PROBLEM OR NOT
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #6
Jame's, he said that he ''Lined the skids''. I suspect that he attach the ''high density plastic'' underneath the shoes. Oh, and you might want to remove your ''Caps lock''. I have to turn down the volume every-time I read you, as caps is often use as screaming. lol No seriously it doesn't bother me.
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #7
I purchased 2 pieces 1/2" x 2 1/2" x 6" from TAP Plastics
I then formed them with a propane torch to curve matching skids.
Then drilled two holes matching the skids and c- bored to set screws well below surface of plastic.
Now going on second year of use and almost as much life left as when I installed them.
Thanks for the information. May I ask which plastic you chose from their web site. I was thinking of choosing the DELRIN, but thought I would check which type is working for you. thanks again for your help
   / JD 1025 W/54"SNOW BLOWER SKID MARKS #9
Delrin is a slick material but real soft, not a good choice. I ordered Polyethylene Sheets - HyPact® UHMW.
TALKED TO JOHN DEERE DEALER TODAY. JOHN DEERE HAS A PLASTIC SHOE FOR THE SNOW BLOWER- M157831, THAT SELLS FOR $18+ FOR EACH. I AM NOT SURE HOW THEY WILL HOLD UP BUT IF IT SOLVES THE PROBLEM....
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
