Buying Advice I like to buy a used tractor
   / I like to buy a used tractor #1
jack707
up North wisconsin
farm trac 555
I have 30 acres and I want to put a deer plot on my land, about 30x24 or so since I want to go this big and wide a walking tiller is out!.I was thinking about a bobcat would this do what I am thinking of doing?.
   / I like to buy a used tractor #2
30 x 24 what? Feet? Yards?
Wooded? Cleared?
Part of the 30 is cleared that's where I'm gonna put my deer blinds so I'm thinking about 30 long by 24 wide or so that should be plenty to keep the deer in the area for me.
   / I like to buy a used tractor #4
Do you mean 30 FEET by 24FEET or ????
   / I like to buy a used tractor #5
feet? I'd rent a machine to do it.. then buy whatever tractor I wanted...
   / I like to buy a used tractor #6
Jeez I'd do that with a shovel and a hoe and go buy me a big cab tractor for spite. With a a tiller I would just wax and never use.:D
   / I like to buy a used tractor #7
yup. i'd not buy a hand tiller for that small plot. I'd hand job it.. or rent a tiller.
ok.. fessing up. I'd go plow it with an old ford and dearborn plow, then disc it. or rip it with the scarifier teeth on my box blade... then run my cultivator over it.. then harrow it... ;) and very likely each of those implements would be on their own old ford too.... :) saves time swapping implements..
   / I like to buy a used tractor #8
Jeez I'd do that with a shovel and a hoe and go buy me a big cab tractor for spite. . . .
LOL! Now THAT made me laugh! Maybe because I was sorta thinking along those same lines. :D
Yeah I could rent the equipment to get the job done. A bobcat would be a lot of fun though. I have to buy a brush hog so I can also get a tiller with it.
   / I like to buy a used tractor #10
Are you thinking skid steer or tractor bob cat? Either would do the job, just depends on how much $$$ you wanna spend..
Water Line Hose (A59076)
Water Line Hose...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
