Slab Construction?
/ Slab Construction? #11
Here is a picture of my slab before it was poured back in 2006. You can see the PVC drain pipes going through the beam and also the water lines stubbed out.
/ Slab Construction? #12
Is all that covered with gravel B-4 pouring the concrete ? I see you are in Texas. My brother and aunt live in Texas and, he tells me most homes in Texas are slab homes
/ Slab Construction? #13
Under the plastic is sand, no gravel. The concrete was poured right in to what you see, after the finished getting all the plastic in (not quite finished in this pic).
/ Slab Construction? #14
Here , all of this would be filled with gravel for the base . Then, concrete. There have been cases where the ground settles (?) causing PVC waste lines/ joints to crack. Knowing what I know, I would at least have a crawl space where every thing is exposed
/ Slab Construction? #15
I can deal with the main water line coming in through the floor, I can deal with the main sanitary/sewage line exiting through the floor. The thought of the entire water distribution and sanitary distribution network disappearing through the slab into parts unknown is a little disconcerting.
Thanks,
Dave
Check out a new house with bathrooms in the basement.:D
/ Slab Construction? #16
So, what do you do when something needs service, start surgically tearing into the slab. I like my basement acess, would even settle for a crawl space, the slab sounds problematic at best and a repair headache when the time comes.
Going to get another look before I sign any papers. There is a local "inspector" that's going to look at the place and give me his opinion.
Surveryor wants approx $1800 to run the boundary, nail down corners and drop intermediate pins, thats about $1 per foot of boundary.
Will update at that time.
Thanks,
Dave
In my son's basement there are removable covers at critical covered plumbing points.:)
/ Slab Construction? #17
Its a regional thing, but here in FL over 95% of homes,multi family, and commercial construction is "slab on grade".
The advantages of water lines under slab (they're not in the concrete, but under) is they are protected, you have less drilling of studs, and less conflicts between the big 3 subs (HVAC, Electrician, and Plumber).
Disadvantage is that if for some reason you have what is called a slab leak (a leak under the slab) you have to pull up carpet/tile and cut concrete.
Truthfully slab leaks are rare, and with the proper device you can narrow the location of one down to a square foot of floor area, and sawing concrete isn't that big of a deal. They use a special stethoscope to listen for the leak I think (never actually seen them do it).
Best case scenario I would like to build an actual house, the lot is big enough (400+ feet on all boundaries) to locate a house closer to the center of the lot.
Current house is too close to downhill boundary and structures on the adjoining lot. I would leave the current house in place as a possible guest house or weekly/weekend rental. Many things to do close by, ski resorts, state parks and forests, trout fishing, deer, bear, turkeys etc.
Thanks for all the input, really appreciate it. This has to be one of the best forums on the web. Lots of experienced members with practical, working knowledge on almost any subject. It's like a virtual general/feed store were folks come to give/receive advice.
Dave
I currently own (along with the bank and county) a 1979 home with a full bath in the basement. All of the sanitary lines as well as the drain for the washer disappear into the floor, I can deal with that.
The water supply to the downstairs bath is overhead, same for the washer.
The major problem I have with the current setup is there is no floor drain(s) in the basement slab. Have never lived in a home without that before. It's a split level ranch. If something in the basement lets go the house will fill up with water. I always shut off the well pump if we are going to be gone for more than a day.
Thanks,
Dave
/ Slab Construction? #20
Most of my family lived for decades on slab homes in FLA. Not one ever had a problem with the plumbing under the slab. My parents only had one basement home. Every other home has been a slab. Our city house in NC was a slab home built around 1975. No problems with the plumbing.
Personally, I HATE crawl spaces and the idea of having a toilet on wood makes me shudder. One morning, our toilet over flowed in our city slab house. To make it worse, the danged toilet kept running so it dumped more water on the floor. :shocked::rolleyes: Did I mention I was late to a closing? The closing on our loan to build our current house? :shocked: After I stopped the toilet, and sorta clean up the mess, the wifey had to deal with most of the water, I went the lawyers office. The closing was a disaster but that is another story. Luckily, the slab was unlevel from the bathroom to the laundry room so the water stayed on vinyl flooring and did not get to the carpet. It would have been worse if we had been on a crawl space or basement. A coworker bought a fairly new house with a crawl space and had to completely redo the bathroom floor because the toilet had leaked and rotted out the subflooring. The floor, including the tile, had to be ripped up and replaced.
When we built our country house we put in a slab. Most people would have put in a crawl space, and given that we have a decent elevation change, so that one side of the house is about 18 inches above grade and the other is about 60 inches, a crawl space would have been a what most people would have done. Instead of a crawl space, the foundation was filled with 67 stone and then a slab was poured over rigid insulation. The PVC is was installed, sealed and pressurized before the gravel was put into place. 67 stone compacts as it is laid and does not settle. The pressure gauges showed no leakage and eventually the slab was poured. No problems in 10 years.
A neighbor has a crawl space and I don't know if they have fixed their messy crawl space. I looked into the crawl space when the house was mostly finished and about to be foreclosed. Long story there. Anyway, the house was maybe 6-9 months hold and the crawlspace was full of moisture and multi colored mold. :shocked: Now that ain't normal in a crawlspace but it is the sort of problems/nightmare one can get. Now a days, I would build a crawlspace that was sealed if I had to have a crawlspace.
A crawlspace to me is a negative, not a positive in a house.
Later,
Dan
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
(INOP) MASSEY FERGUSON 253 TRACTOR (A59823)
(INOP) MASSEY...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
