Ideas on building a weight ballast box for l3240
   / Ideas on building a weight ballast box for l3240 #1
lockman4288
Member
Wiscasset,ME
3240 HST TLB cab
Looking at building my own weight box looking for some ideas images or drawing with some dimensions would be great or if you have a price on a factory kubota one that would be better and save my time would be awesome
   / Ideas on building a weight ballast box for l3240 #2
Run on sentience much ?
   / Ideas on building a weight ballast box for l3240 #3
Good Evenin Lockman,
Try using the search feature, there have been a bunch of nice weight box ideas on TBN. Myself, I just used a steel drum, cut a couple of holes through it about a third of the way down the barrel, an got a steel rod that runs through the barrel, filled it with rocks and concrete. Its not really pretty but it does the job of adding weight when using the loader and durring the winter months...:)
   / Ideas on building a weight ballast box for l3240 #5
What tractor are you wanting to put it on? Many of the ideas that you will find can easily be modified to the weight desired. I am working on a similar project myself.
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2014 Ford F-150 Pickup Truck (A49461)
2014 Ford F-150...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Case 830 Tractor (A50514)
Case 830 Tractor...
2021 Exmark Lazer Z 60in Zero Turn Mower (A49461)
2021 Exmark Lazer...
