Would like honest suggestions about tow vehicle issues
   / Would like honest suggestions about tow vehicle issues #241
03 cummins, 19MPG no matter what I do with it. Bone stock. 2 jeeps on a goose from C Springs to Moab 15MPG. Mojor Maint since new? Valve adjustment and radiator hose and a water pump. Since the cummins is based on a commercial engine, the water pump was a 20 minute job and looses very little anti freeze when you pull the pump. Its 3 bolts and a belt. Now that I have figured out to let Cummins do maint on it, its cheaper than dodge and they know what the **** theyre doing.
Get a prius or go home
   / Would like honest suggestions about tow vehicle issues #242
I would agree with you...but then we'd both be wrong.
Your prius will get better gas mileage, right up till we hook a 30ft horse trailer to it. Then lets see how well it does.
   / Would like honest suggestions about tow vehicle issues #243
I hate prius I just say that to ford and dodge fans I'm a chev guy
   / Would like honest suggestions about tow vehicle issues #245
That says a lot....
Chris
Hey now we (as in non-ford lovers) make no claim to him. :laughing:
All of his statements include "we" when referring to different vehicles/tractors he says he has. This to me indicates that he doesn't actually own any of them... probably Daddy of Grandpa or Uncle Cletus I would have to assume.
What I would like to know is how did my thread turn into one about a pppprrrriii? I cant even say the word.
I like the way one of the diesel mags "recycled" a pppprrrrriii, ran over it with a tank. :)
I am so fed up with this government forcing our hands in soooo much of our lives.
Now back on topic, what major flaws should I look out for on a 00-03 (early 7.3 model) Ford? Am seeing some of those at very attractive prices.
   / Would like honest suggestions about tow vehicle issues #248
I own a 2000 F250 w/automatic and 3.73 gear ratio and I would say to look for leaks in the valley of the engine which will show up at transmission bell housing area like a rear main seal leaking, also leaks at oil cooler on drivers side of motor under exhaust manifold area. The transmissions are a weak point but if you beef it up and use a triple disk converter you will be in good shape. Also recommend trans.temp gauge and a 6.0 cooler if you tow a lot. Mine has been a very good reliable truck that I tow 10,000-12,000 lbs with almost every day in FL. heat. Also check the injectors as they are a costly repair usually around 200,000 or slightly more, depending on individual truck. Overall I am very happy with the 7.3 it is a awesome motor for longevity.
John
   / Would like honest suggestions about tow vehicle issues #249
Oil leaks, injectors and transmission. Overall they are very reliable
   / Would like honest suggestions about tow vehicle issues #250
I thought I lost the original post sorry
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
71054 (A49346)
71054 (A49346)
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
