Your towing rigs and trailers
   / Your towing rigs and trailers #1,561
Here's my set up. 2010 F150 FX4 with Trailer Pkg, trailer sway bar and electric brake system.
Trailer is an 18 foot Load Trail 7000 GVW. Truck just turned 7,000 miles. Don't get out much. :laughing:
Dano
Looks good.
   / Your towing rigs and trailers #1,563
   / Your towing rigs and trailers #1,564
Heres the update on Mine:
1994 Ford F-350 4x4 Work in Progress.
12 valve Cummins, ZF 5 speed, Valair Dual disk Clutch, Low pressure Piston Lift Pump, 19.5" wheels with 33.5" tires, Modernized Interior. To many hours and Dollars to count in the rebuild.:eek:
Paint coming soon as well as new front springs, better turbo/ Exhaust
I'm digging your truck. I often think about having a flat bed on a work truck.
   / Your towing rigs and trailers #1,565
Here is mine.
2013 F350 SRW and Load Trail 20+5 Gooseneck deck over with MPED ramps.
   / Your towing rigs and trailers #1,566
Here is mine.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347440"/>
Nice setup.
Sent from my GT-P3113 using TractorByNet
   / Your towing rigs and trailers #1,567
Nice.... Nothing better than a SRW 4x4 F350.
Chris
   / Your towing rigs and trailers #1,568
new addition to the fleet:
it's a 97 F250 HD with the 7.3 powerstroke, e4od automatic, and 4.10 rear end. it also has the front axle from a f350 (ie, a solid front axle) but it rides pretty well, considering.
   / Your towing rigs and trailers #1,569
Bet that's a good pulling truck! Looks in great condition, too!
   / Your towing rigs and trailers #1,570
Here is mine.
That's pretty.
Sent from my iPhone using TractorByNet
2014 Toro Workman HDX-D Diesel Utility Cart (A55851)
2014 Toro Workman...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
Frontier Hay Spear (A56469)
Frontier Hay Spear...
