Draining the hydraulics on my Kubota L3200
   / Draining the hydraulics on my Kubota L3200 #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I'm coming up on my 50 hour filter service. I was going to use the shop vac trick to keep it from leaking too much. But now I'm about to add in another set of valves for TnT & what not I'm assuming I need to drain it all to plumb it in. Is that correct?
My HST has 6.2 gallons of fluid according to the owners manual. How much of that might make an appearance when I start draining? Will a 5 gallon bucket be sufficient with a lot of the fluid stuck in the loader, 3pt & HST plumbing? Or do I need to swap buckets mid drain or find a bigger drainpan/bucket?
Any dyes or what not I could put i so I can actually see the fluid level in the sight glass? I still cant figure out if I'm overfilled, underfilled, or what given the dam clear stuff in there now.
   / Draining the hydraulics on my Kubota L3200 #2
You don't need to drain anything to change or add new valves.
   / Draining the hydraulics on my Kubota L3200 #3
John Deere sells a red dye made for hydraulic fluid. You can add that to your transmission.
   / Draining the hydraulics on my Kubota L3200 #4
Having trouble seeing the fluid level in the little sight glass? This small bottle of red dye is cheap and will last forever since only a few drops are needed to dye the fluid a red color. JD (Yanmar for sure) uses this at the factory to help identify leaks, but after one or two oil changes the color is gone and the HyGard fluid is very difficult to see.
Part Details
Part Number: MT3668
Part Price: 3.91 USD
Description: FLUID, HYDRAULIC OIL DYE
I have the pull the tank hose off the hydraulic junction block which is about level with the bottom of the transmission case. Won't that mean all the fluid inside will suddenly decide it wants to be outside via that no open tank port? All the other hoses go into that block down at that level too.
   / Draining the hydraulics on my Kubota L3200 #6
If it does, just have a plug ready and a cap for the hose.
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
