half ton chevy tow 9200lbs?
   / half ton chevy tow 9200lbs?
I pulled a 7400lb bobcat skid steer on a 16ft dual axle trailer one time with my fathers 1500 z71 but boy was it loaded down. picked the truck about 4 feet off the ground with suspension flexed all the way out when loading and unloading...
   / half ton chevy tow 9200lbs? #12
Yea....go ahead and do it......let us know how it goes. Maybe the wife could drive the truck......at least you'll have someone to blame when things go bad. Just kidding......wouldn't do it.
   / half ton chevy tow 9200lbs? #13
haha! YEAH! if I were to let her drive im sure she would find the only cliff in Mississippi and never see coming
   / half ton chevy tow 9200lbs? #15
put something under the back of the trailer to keep from picking the truck off the ground
   / half ton chevy tow 9200lbs? #16
What town are you in? I want to scan the newspapers there to see how this turned out. :D
These guys seem to rate it at 6500# , with a 5.7.
Tow Capacity Rating Look Up by Trailers.com - Look Up Tow Vehicle Ratings and Tow Capacity
Guessing that is a 7,000# rated trailer, so you at least 2,000# over the trailer rating. Definitely a tire-killer, trailer wise, and you're gonna be beating up your truck, and overmatching your brakes.
Rgds, D.
dang I just looked at that.. doesn't look to good.. I may try to call a towing company and see what the rates are..
ok that's a good idea. haven't thought of that!
haha you would have better luck looking in the guiness book of world records for half ton truck took worlds worst beating
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
LOT: (3) Water Meters, (2) Valves (A59076)
LOT: (3) Water...
TANK MANIFOLD (A58216)
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
Entyre Chip Spreader (A57453)
Entyre Chip...
1667 (A57192)
1667 (A57192)
