fall round?
   / fall round? #1
Sheepdr
Member
fernley,nv
4330 kabota
I hope I'm putting this in the right place.
If I spray round,or the like, on my fence lines and borders this time of year will it have a residual affect in the spring to help me get e jump on spring weeds or am I wasting spray and time?
   / fall round? #2
I don't like round-up on the fence lines... All the grass dies and weeds take its place. Some of the weeds are harder to wack than grass.
   / fall round? #3
Glyphosate weed killers only work on actively growing plants. So, to answer your question, no. You need a pre-emergent type weed killer for that.
   / fall round? #4
It would depend on the growth as was mentioned already. It is a bit late as Sept is a great time as the plants are pulling back you are able to get the glyphosate and others chems to get the roots very well.
   / fall round? #5
you can spray spike in the winter.it will kill everything.
   / fall round? #6
Same here, you spray Round-Up and you'll have weeds come back every time.
   / fall round? #8
farmer2009 ,never herd of pramitol is it comparable to spike?
   / fall round? #9
I am not formilar with Spike. But Spike looks to be similar but not sure the same. They both have soil activity, but Pramitol is a ground sterilizer not sure about spike. But to get spike to control a wide spectrum of weeds and grasses you must apply 5.0 lbs per acre and as that is a 2 year rate you must have skipped the previous year. So to me it's not a use every year product like Pramitol is. Maybe someone that is formular with it can help more.
   / fall round? #10
i guess spike would be a ground sterilizer.it will kill for 3 years.you can get some growth on top of the ground, if there is enough water to move spike past the root zone.
FRONT MOUNT POLY TANK W/ MOUNT (A52708)
FRONT MOUNT POLY...
4R RIPPER BEDDER (A52708)
4R RIPPER BEDDER...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
gps trailers (A56859)
PALLET OF TIRES & GAS BOTTLE (A58374)
PALLET OF TIRES &...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
