How to auger a 18" hole through sand that's collapsing
   / How to auger a 18" hole through sand that's collapsing #21
For the sonotube to drop down into the hole, the hole has to be bigger than the sonotube. This would leave a gap around the footing.
That depends on how loose the ground is. If it's loose enough, it will fill in against the tube.
   / How to auger a 18" hole through sand that's collapsing #22
That's true, but would you want the footings on your building located in loose soil in a sonotube that lacks any soil friction or lateral support? Most structural engineers will not allow sonotube below grade unless it is engineered that way.
   / How to auger a 18" hole through sand that's collapsing #23
What I have always done is dig the hole, bell the bottom, fill half way or so, then sonotube the last foot or so.. Gives nice footing on top, but allows the ground to resist heave.
   / How to auger a 18" hole through sand that's collapsing #24
I'm wondering why they placed and compacted the sand before they poured the footings? It would have been a lot easier to drill them into the firm subsoil then compact the sand around them. It still might be easier (and cheaper) to pile the sand off to the side and bring it back later.
   / How to auger a 18" hole through sand that's collapsing #25
I believe the sand is part of the natural geology in those parts.
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
71068 (A49346)
71068 (A49346)
2025 LandHonor UHA-16-3000G 2in Utility Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
