Building a usable toolbox
/ Building a usable toolbox #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
The toolbox that was standard on my Bobcat CT225 was just slightly north of useless. Seriously, what was the point of that plastic afterthought? I could barely fit linch pins in it, much less any necessary tools. After rummaging around in the shop, I found just what I needed to remedy the situation and have some useful storage. For less than $7 in hardware and an hour or so of cutting, gluing, and screwing, I have a real toolbox.
The original "toolbox"
Barely bigger than a glove...(perhaps it was really a glovebox)
20x10x10
A small section for pins, etc., plenty of room for a chain or two and necessary tools.
I'll probably paint it either white or black...and there is room to mount a SMV triangle
It will look better with a coat of paint.
/ Building a usable toolbox #2
Looks good now, even. :thumbsup:
/ Building a usable toolbox #3
My gosh, something even smaller than the almost useless one Kubota puts on their tractors!
Yes, I've been very tempted to mount a real toolbox on my tractor. Good job.
/ Building a usable toolbox #4
Yeah, the tool box on my NH Boomer 3050 is actually smaller than the one on you bobcat and made out of flimsy, thin plastic. To add insult to the situation my NH manual says it's supposed to be stored in the tool box. I can just see some unwitting newbie try to roll his manual into a tight circle and stuff it into a box that is not even water tight. It would ruin the manual and there would not even be any spare room for one lynch pin. Though I love the performance of my 3050 Boomer there are other odd things about it where one wonders if the engineers and designers have ever driven a tractor.
/ Building a usable toolbox #5
You shouldn't have any complaints now. Plenty of room. Nice work.
/ Building a usable toolbox #6
I think, judging from the size of that thing, it would be more appropriate to refer to it as a trunk, rather than a tool box. :thumbsup:
/ Building a usable toolbox #7
You should send that last photo to the company and tell them that's what a real toolbox looks like.
/ Building a usable toolbox #8
:thumbsup:
I am more coming to believe that those are glove boxes Kubota puts on their tractors, not tool boxes!
/ Building a usable toolbox #9
Looking good!:thumbsup:
Enough room back there for a box with drawers.
/ Building a usable toolbox #12
Very nice
/ Building a usable toolbox #13
Looks good with the paint job
/ Building a usable toolbox #14
That looks like a usable sized box and it looks good, but it too is not waterproof so some drain holes in the bottom might be in order. I put one about that size (18 L x 8W x10D)on my LS (it didn't have anything) but I bought the plastic waterproof tool box at my local farm and ranch for $15. It is large enough to hold a 15" adjustable wrench, hammer and other tools. I took off the steps from the right side since I don't use them anyway and fabricated a bracket to hold the tool box. After assessing the tractor for locations, this was the only place that was suitable for accessibility and high enough of the ground to prevent damage to the box. I built the bracket so the top of the box is just below the cab door. I couldn't put it behind the cab like yours as there it would interfere with top link and prevent sight from seat to the rear of the tractor implements
/ Building a usable toolbox #15
I also mounted a tool box on my B26 using the bracket for the SLV which was welded on to the FOPS rear post. Using that and some self tapping screws I built a bracket that mounted there securely without welding directly on the FOPS support. It worked perfect and is just the right height to be able to look inside for an item. It will hold about 3 bottles of water + tow strap, some extra snap pins, gloves,10" adjustable wrench and channel lock pliers. I don't find that I need anymore space for other tools. If it requires more than that, I return to the shop for repairs.
/ Building a usable toolbox #16
Very nice job. The paint looks amazing!!!
Eddie
/ Building a usable toolbox #17
Nice job and big enough for a couple of sammiches for a long days work!
Great Dane Van Trailer 1989 (A63118)
Great Dane Van...
Arrowquip Heeler Portable Corral (A64047)
Arrowquip Heeler...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
APPROX (19) 6'X12' SITE FENCE PANELS (A62131)
APPROX (19) 6'X12'...
