LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #71
Same price my dealer had for local pickup, but since he went out of business that seems like a good deal
BTW if you have the 3038 I have the filter cross except engine oil filter
Original: WIX
Oil Filter PN 40006977 n/a
Fuel Filter PN 40006997. 33128
Outer Air Filter PN 40007575. 46438
Inner Air Filter PN 40049447 42985
Hydraulic Filter PN 40007638 51715
Transmission PN 40007563 51551
   / LS Tractor Oil, Gas, & Air Filter Information #72
Hello J2020H owners,
If you are like me and have a relatively new J2020H tractor you will come up on the first 50 hour maintenance check and then find little in the way of easy information regarding items such as oil filters, suction and HST filters. I will probably go with the LS recommended filters for the first OIL, hydraulic suction and HST so as to not void the warranty period, however, I wanted a local source for future oil filter changes and as such I have found that following filters cross reference to the LS J2020H or the Mitsubishi 3SL engine in the J2020H:
Lube Finder PH2876, Fram PH5541, Fram PH6607, Purolator L14612, L14622, WIX 51365
Here is what I used for cross references and since I am relatively new to the world of subcompact tractors there is the unavoidable assumption that the cross references lists are accurate so as always buyer beware:
Lube Finder URL that references the LS J2020H: http://www.luberfiner.com/catalog/part-detail.aspx?id=000277173&partno=PH2876
Cross Reference for K&N Filter Part Number HP-1008: Cross Reference for K&N Filter Part Number HP-1008
Hydraulic Store PH2876 Interchanges: http://www.hydraulicstore.com/index.php?loc=items_detail&data[itemcode]=3977839
I hope this helps.
   / LS Tractor Oil, Gas, & Air Filter Information #73
R4041H NAPA #
I have all the NAPA filter numbers for my R4041H except the HST transmission filter, can anyone help?
   / LS Tractor Oil, Gas, & Air Filter Information #74
2013 LS R4041H Engine - S4QL
Oil filter / OEM # 40006977 / NAPA # 1064 / WIX # 5106453
Fuel filter / OEM # 40006977 / NAPA # 3128 / WIX # 33128
Hydraulic Filter / OEM # 40007638 / NAPA # 1715 / WIX # 51715
Hydro Transmission Filter / OEM # 40007563 / NAPA # 1551 / WIX # 51551
Inner Air Filter / OEM # 40049447 / NAPA # 2985 / WIX # 42985
Outer Air Filter / OEM # 40007575 / NAPA # 6438 / WIX # 46438
   / LS Tractor Oil, Gas, & Air Filter Information #75
I have a 2012 LS R4047, can someone please post the part #'s for the filters? Thanks!!!
   / LS Tractor Oil, Gas, & Air Filter Information #76
The filters are the same for the 41 and 47 so the the answer to your question can be found below.
   / LS Tractor Oil, Gas, & Air Filter Information #77
Just in case anyone has started pricing the filters from dealer vs Wix I see a big differance in pricing, Dealer is 30-40% more.....Went to local Wix dealer and of course some he did not have and ordered, fair price. I alos order filters onlne for Diesel generator and other equipment and took a shot at ordering, looks like they are 30-40% cheaper than local dealer even with shipping and since I order $125+ I get another discount..check out Fleet Filter dot com and plug in the numbers. Not selling for them just know buying a ton of filters you uhave to be able to save some cash
Local Fleet
LS Fuel 33128 $18.90
LS Hyd 51715 $46.02 $29.92
LS Inner 42985 $20.67 $14.96
LS Oil 51064 $5.01
LS Outer Air 46438 $26.91 $17.50
LS Trans 51551 $9.34 $6.07
Still waiting on a few to come in to get a complete comparison
   / LS Tractor Oil, Gas, & Air Filter Information #78
I probably shouldn't post this but I work for a trucking company and we buy a huge amount of filters from NAPA and I got my 6 filters for my 4041H today .
I guess volume does matter! Must be huge mark-ups on filters!
   / LS Tractor Oil, Gas, & Air Filter Information #79
same number ???
   / LS Tractor Oil, Gas, & Air Filter Information #80
Fuel filter / OEM # 40006997 / NAPA # 3128 / WIX # 33128
Your right RAYJAY must have been a typo on the fuel filter. Correct OEM Fuel filter # 40006997. I think everything else is correct. I don't know how to edit or delete the incorrect post or I would.
2003 International 9200I (A53317)
2003 International...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
DEUTZ MARATHON...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2007 Volvo VNL Truck Tractor (A56436)
2007 Volvo VNL...
