My Stihl MS 290 died after less than 60 days...
/ My Stihl MS 290 died after less than 60 days... #21
Fuel that doesn't contain Ethanol all I use as well but why do I have to use it? I think some say it has something to do with the material used for fuel line and gasket material in small engines, that larger auto engines use materials that are impervious to Ethanol? Why don't the small engines just use that then? Or... is it that fuel that contains Ethanol absorbs water? Again, then why don't they just construct small engines in a way that tolerates that? It looks like these additives are here to stay so I don't know why this is still a problem for new small engines.
Good questions!
/ My Stihl MS 290 died after less than 60 days... #22
I am no expert, but I thought newer gasket materials are fine with ethanol blends but the absorption of water is the problem. Cars don't sit for months typically such that they collect as much proportionally? I run ethanol free mid grade fuel only in small engines.
/ My Stihl MS 290 died after less than 60 days... #23
E-10 fuel line is available these days, same with gaskets, etc. The E-10 is the problem, not the engines or their materials. Car engines are closed fuel systems, chainsaws, weedeaters, 2 cycles in general are NOT closed to atmosphere, allowing E-10 to do it's water absorption thing, and phase separation, etc.
Stihl knows what E-10 does to the carbs; microscopic water molecules create rust inside the carb passages, especially when E-10 sits in the carb over time. The passages, jets, etc., cannot be cleaned enough to render the carb to work properly, and then the carb needs to be replaced. Vicious cycle, repeats again and again. Carbs can't be designed to get around these issues without astronomical expense due to need to comply with stricter and stricter EPA specs.
Solution is to use E-10 free fuel and eliminate the problem. Treat the problem, not the symptoms. The additives help treat fresh E-10, they DON'T make it water free if it's been in an underground vented tank absorbing water and phase separating prior to the consumer purchasing it. Once it breaks down it can't be unbroken, no matter what you add to it.
/ My Stihl MS 290 died after less than 60 days... #24
E-10 has been with us for what?, 20-40 years or so, (seems like forever). It is about time small engine manufacturers got their heads out of the sand and built engines to cope with the alcohol problem like automobile manufacturers did.
That said, for the present, most areas do sell (or at least claim it is )alcohol free pure gasoline. Even so I still treat mine with Stabil as soon as I buy it and change it out at least every 2 months by pouring the remaining fuel in my automobile and refilling my containers. On my riding lawnmowers, which I cant easily remove all the gas, I run it down low as possible and double dose it with Stabil, then fill them up for spring mowing. Once I forgot to dose my Craftsman with Stabil and it wouldn't even fire up with the old gas. Thought I was in for a carb rebuild, but after removing the tank and draining, then putting in fresh gas, it started right up.
As for scouring the cylinder, I have never heard of that happening from the fuel unless 1) you didn't properly agitate it after setting for a long time which "could" have cause oil separation from the gasoline or 2)it wasn't properly dosed with 2 cycle oil to begin with. I try to remember to give my fuel can a vigorous shake before filling it and if some has been in the equipment tank, I give them a shake also.
/ My Stihl MS 290 died after less than 60 days... #25
My bet is it wasn't the gas/mix, but just something wrong with the saw.
That said, I don't like the 290 at all and would upgrade to a ms 261 if I had to stay with a Stihl...
/ My Stihl MS 290 died after less than 60 days... #26
The 261 is certainly a way better saw, but I'd be surprised if the dealer was able to let Nick upgrade if there is a warranty replacement. Probably getting another 290 is the best hope.
/ My Stihl MS 290 died after less than 60 days... #27
I was thinking more like a trade in. He will take a hit, but well worth it!
Still waiting on a decision & considering my options for various scenerios. If the matter is handled under warranty then the MS 290 comes home. If the warranty claim is denied but the dealer makes a significant offer to meet me part way, I might prefer upgrading to a MS 261 (with more out of pocket for me) than going the MS 290 route again if that is a possibility.
My biggest reservation about the 290 is that I have yet to hear an explanation for what happened. The fuel used was good & is the same jug used for our Stihl blower & trimer, which have both seen a lot of recent use & are running strong.
If I get left hanging then I may end up going with a locally available Jonsered 2250s as a replacement. I won't put money into repairing the 290 via the dealer as the projected parts cost alone there would be 2/3 cost of a new saw & I can't see taking a chance on another unexplained, non-warrantied, melt down by buying another 290 at full price.
Nick
/ My Stihl MS 290 died after less than 60 days... #31
Have they given you a date for when they expect an answer? Asking for a loaner might encourage them to get on the ball.
I thought they were going to hear from Stihl on Friday, but it apparently didn't happen. Hopefully things will get nailed down on Monday. We've been doing other things while sawless, spent the last three trips to the rental removing & breaking down bamboo that had come in from a neighboring yard over the last few years. The circular blade (chain saw style tooth shape) mounted on the FS90 trimmer does a great job on bamboo, BTW...
Nick
/ My Stihl MS 290 died after less than 60 days... #33
I have the same problem with my tractor. Yesterday cleaned the prescreen in the glass bowl, the filters and the tank. There was snot in it, probably because i took a can of fuel from the local gas station instead of an agricultural diesel supplier. Here, 10% biodiesel is mandatory blended in, but subsidized so some privately held gas stations have their wholesalers blend in more biodiesel to get more subsidy. (you do 100km less on a tankfull compared to what you buy from Esso, Shell Aral or any other major brand)
Oh, and when i put a rag around the air pistol and put it on the fuel cap opening to get it to flow a bit harder, the smell was horrible, smelled like dead animals. Biofuels are hygroscopic which means they absorb water, which makes it possible for bacterias to grow inside. When they started adding biodiesel, customers at work had several serious Common Rail system failures, both on Bosch systems on Cummins engines as well as Denso systems on Deere engines: All customers who took a 1000 liter tank with them to a construction site where they stayed for some weeks, so the fuel had a lot more time to attract water and grow bacterias. when you get fresh fuel at the gas station its not a problem, but with small engines, or hobby tractors, they sit for extended periods of time, in which the fuel can grow bad.
/ My Stihl MS 290 died after less than 60 days... #34
Nick
Bamboo is very hard to control. Don't just cut it, you must treat the ends too. Get ahold of your County to find out what product is good for your area.
Okay, finally got a decision. The dealer indicated the mix was bad - foreign material & water.
That totally floored me. I brought in the mix jug & compared the material they collected from the saw with what I had in the jug - totally different in appearance. My Stihl mix looked just like what they used in house - light greenish tint to the fuel mix. What they indicated came out of the saw looked like it had been mixed with black ink - not opaque but definitely blackish and with about a third of a teaspoon of water rolling around at the bottom of the bottle.
It was something I have absolutely no explanation for - from the time we got the saw home, the only fuel used came from the jug we bought as the same time as the saw. Only two batches of mix have been done in that jug, each mix consisting of two gallons of 93 octane direct from the pump into the jug with two 2.6 oz. bottles of the Stihl Ultra HP oil & a tablespoon of Star Tron for alcohol mitigation. The saw never got the "dregs" of the mix jug & I have fueled our Stihl FS90 trimmer & Stihl blower from this same jug multiple times with no adverse affects.
The up side is that they are fixing the saw at no cost even without going through the Stihl warranty process. The service manager said they wanted to take care of a good customer & that he believed that I had not knowingly done anything to abuse the saw. I really appreciate a business that goes the extra mile!
Regarding the bamboo harvest, we took the Aluma over to haul off the canes. Carried them over the the acreage & put them on a old fuel oil tank frame.
Plenty of cane poles for the fishing pond... (or tomato stakes - or bean poles - etc.)
Nick
/ My Stihl MS 290 died after less than 60 days... #36
Well that is really good news but the fuel story doesn't make sense. It might be a jar of fuel they trot out every time they do a "good customer" repair for free. Haha.
/ My Stihl MS 290 died after less than 60 days... #37
Maybe there was something in the tank before you put your fuel in? Sure seem weird though. Glad they're taking care of you and fixing up the saw!!
/ My Stihl MS 290 died after less than 60 days... #38
Hmm, doesn't make sense, but I'd say be darn sure you have the fuel situation worked out. Had a neighbor trash a brand new 441-CM with bad fuel, and it was a similar situation. Maybe ethanol reared its ugly head....
Yeah, I think I'm going to be pretty fuel paranoid from now on. Probably start emptying equipment that has been unused for any period of time before fueling rather than topping off before a job & then eyeballing what comes out and what is going in each and every time....
Nick
/ My Stihl MS 290 died after less than 60 days... #40
It happens.
I leave mix in my saws and trimmers year around, but it is eth-free mixed with good oil... No problems here. Have also had year old mix that looked and smelled fine...
UNUSED IRANCH IRTPL 10000Ib TWO-POST CAR LIFT (A60432)
UNUSED IRANCH...
POWERTEC INDUSTRIAL BRUSHLESS P.M.A.C SERVO MOTOR (A60432)
POWERTEC...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2018 Chevy Traverse 3rd Row Seating (A61306)
2018 Chevy...
