Oil
Synthetic oils do not cause leaks, they have seal swellers. If you have maintained your tractor with regular changes, you will be fine. If you have neglected it, the synthetics ability clean the sludge out may find a leak, but will not cause it.
Please tell me what formulation is "seal sweller"? Most Nitrile, Buna-N, seal material is impervious to oils and additives.
Go do sone reading on places like BITOG. When synthetics first hut the market, they gad a rep for 'causing leaks'.
I'm very familiar with B.I.T.O.G., a tier lll "back shelf" oil enthusiasts forum. but I couldn't find any information there to back up your "seal sweller" claim. I also did a cursory glance at SAE International (yes, I'm a past member) and found a white paper, Lubricant Formulation Effects on Oil Seal Degradation , that pretty much explains why seals fail. You can read it if you want - $25.00. Tell me what you think. Also, tell me more about "seal swellers". I would deem your posts even more credible if you quoted or referenced something from The Official STLE Web Site | Society of Tribologists and Lubrication Engineers or SciTech Connect: .
Let's try to keep snake oil stories and old wives tales to a minimum - if at all.
Show me some free data backing your claims up.
Krane's Synthetic Oil Survey
Synthetic Oil and Swell rate - The Garage Journal Board
Seal Conditioners/Swellers in HM vs Synthetic Oil - Bob Is The Oil Guy
And if you are really bored with yourxelf, argue with the folks at Mobil.
Will Mobil 1 High Mileage Help or Contribute to Leaking Seals
Want to sell papers, get a paper route.
I really don't have much time for sales people. Especially those that just use their Google skills.
Mobil? Really?
All your information is free, handed to you on a platter. What are your credentials that let you speak with authority on lubrication? Never mind, I'm not going to be trolled.
I digress.
I wonder what Carl Bert thinks . That will surely start another war . Why do you people always get into a pissing match ? Oil is oil , keep some in it .
/ Oil
I guess I shouldn't have brought this topic up. Just wondering about the conventional versus synthetic oil. I guess I could change back to a conventional diesel oil and see what happens.
Cory
Nothing (bad) will happen. I had four Chinese tractors, and never saw a need to put synthetic anything into any one of them.
//greg//
As always, use of either type will not void your warranty, so during that time who cares? If, though, you are using the tractor in very cold climates, or very hot, synthetics have shown to have better flow properties under these conditions and their use should be considered.
The type of synthetic used for engines is polyalphaolefin, fancy chemist talk for long chain hydrocarbon polymers. Same as refined mineral oil except much less variation in length & linkages, and no junk (sulfur, chlorine, wax, etc.). So......why the different impact on elastomeric oil seals? Lubricity....synthetic flows easier, so if you have an incorrectly clamped seal, it will leak faster with synthetic. Simple.
Anyway, for cold temps you want synthetic for quicker pumpability & flow to critical parts on startup & warmup - if you put substantial hours on your engines for longevity. Also in the heat, synthetic does not oxidize (burn/varnish) nearly as quickly - critical for turbocharger bearings.
I use synthetics - change once a year, don't worry about anything. App. 105 hours on new SCUT in 6 mos.
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
