wont start
/ wont start #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
I have a JD 4410 that has intermittent no start issues I think its in the safety switch for the gear selector because if you can get it into just the right spot it will engage the starter.
Any ideas on what to look for?
/ wont start #2
My JD750 has been like that for years. I look at it as an anti-theft device. If you don't pull up on the PTO lever and joggle the shifter, it ain't gonna start.
Not enough of a pain for me to take the time/spend the money to fix it.
The :censored: charging system, on the other hand...:muttering:
/ wont start
now its to the point I cant get it to roll over at all
/ wont start #4
My Simplicity garden tractor had the same problem. I also thought it was a safety switch problem, turned out it was the solenoid on the starter that had gone bad. For a short period of time if I would tap on the solenoid with a hammer, it would start.
/ wont start #5
Check for loose or sloppy links down to neutral start switch,also connections/ wires ex......
/ wont start #6
You've already figured it out yourself. Its the safety switch for the gear selector. Either it's out of adjustment or faulty. Go under there and see.
/ wont start
I should have looked at the battery first .... the bolt on the positive clamp was corroded through put a new bolt in and it was good to go.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2012 PROCCO 130BBL (A65643)
2012 PROCCO 130BBL...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
