Kubotafan
Gold Member
- Joined
- Jun 25, 2012
- Messages
- 310
- Location
- Nova Scotia, Canada
- Tractor
- G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a G1800 tractor and if has been setting for a few days or left out in some rain it won't start with the ignition key. When this happens I jump the solenoid switch to get it started, and usually that will have the key working again. Also, sometimes the glow plug will not activate off the ignition switch, and I have to jump it too. I suspect the cause of this is either a bad ignition switch and or a computer problem. Rather than spend the money to replace them I want to put on two switches so that when the problem occurs I can just push a starter button to start it and another switch to activate the glow plugs. I am wondering how heavy duty a switch I would need to use for this? I suspect the switch for the solenoid could be a regular push button switch, but would the glow plug switch have to be something more heavy duty to handle the current draw (the wire I use to jump it can get warm after holding it for a few seconds)? A link to a supplier could be helpful (I am in Canada so a Canadian supplier could be easier to buy from).
