New Kubota owner - Need some help
   / New Kubota owner - Need some help
Thanks for the help. I was able to get the brush hog off and the mid mount mower attached. It took me awhile longer to get the MMM attached, but after some time got it in a now have a nicely mowed back yard!! Thanks again. I'm sure I'll more questions later. :)
   / New Kubota owner - Need some help #12
Good to hear, as James said, never gets easy just not as hard.
   / New Kubota owner - Need some help #13
They are pretty easy to get off, getting them back on can be interesting:). Pick a spot to take off your rotary cutter in the most level piece of ground you can find.. Get some wood or something to put under the front of the "hog" so it doesn't sit in the dirt. Make sure your PTO shaft is well greased between the two sections and pointed down or covered. Rain can rust them together. When you go back to hook up. take it slow and easy to get lined up with your turnbuckles loosened up to allow the arms to move enough to go over the ends of the pins. I don't think you have telescoping links, so get a big prybar to pry the "hog" around to line up things.. be sure your swear word vocabulary is updated to all the latest verbs.:) Wear heavy boots so you wont hurt your feet by kicking the sheet out of things:). Come back later and we can talk about quick-hitches.:thumbsup: Good luck, have fun, stay young, and drink Pepsi:D
James K0UA
HAHA!!
   / New Kubota owner - Need some help #14
One of the best things I ever got for our BX's was a set of stabilizer bars to replace the turn buckles from hodge: StabilWorks
I'll second this suggestion. The StabilWorks bars greatly reduced the time & vocabulary associated with getting a tiller attached and removed from our B5100. I should probably get another set for our new B2320.
   / New Kubota owner - Need some help #17
I love these posts. On thing I have learned in the couple months I have had my Kubota, is a flat surface and patience are a must. Good to know that it will never be a breeze, but isn't horsing around fun?
   / New Kubota owner - Need some help #18
Looking forward to them. Ordered mine this week. :)
You will love them, some of the best money I ever spent.
Yep, it gets "easier" with time and experience, but it never gets "easy", at least not so far.:laughing:
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
