thinking of hydraulic sliding tines on forks?
   / thinking of hydraulic sliding tines on forks? #1
footer200
Bowmanville Ontario
John Deere 4300
Has anybody added hydraulic sliding tines to there forks? I remember seeing a post (can't locate it now) of someone trying to control there bucket attaching pins for a quick attach? I have seen the common body 2 piston cylinders but price wise and to get the travel I require I am thinking of 2 separate cylinders. Any experience or ideas are welcome?
   / thinking of hydraulic sliding tines on forks? #3
If you use 2 cylinders on 2 circuits you can slide forks left & right as well as width. If everything is on 1 circuit I'd expect that a sticky fork or what not could make the whole thing slide one way or the other on its own when you adjusted width.
   / thinking of hydraulic sliding tines on forks? #4
We did it on a BIG forklift that you could not slide the forks, forks are 20' long for a marina so moving them had to be done hydraulicly. 2 cylinders and 2 control valves. 4' stroke cylinders we attached opposing one another then attached to the top of the fork loop. Works great. biggest problem was getting the hoses reeved through pullys to extend the 30' mast height. CJ
94BULLITT thanks for that link I see they have used 2 cylinders on that set up. Looks like that is what I am going to do just to get the travel I need on my Horst Welding forks. thanks
   / thinking of hydraulic sliding tines on forks? #6
No problem. Post some pictures when you get them done. I think is called a side shift. Next time you are at a place like Lowes or Home depot you could sneak a peek at one of their fork lifts so you could see how it is done in person.
Well I bought a couple cylinders out of the sale bin with a 10" stroke 60 bucks each. I have the brackets made up and tack welded on, everything works and lines up good so I will try to get all plumbed up Sat. morning. Yes I welded directly to the tines, no safety police please.:confused2: hydro forks 2.jpghydro forks 3.jpg
   / thinking of hydraulic sliding tines on forks? #8
Cool, I'll be interested to see how it works out.
   / thinking of hydraulic sliding tines on forks? #9
That would be an interesting setup to see. Sounds huge.
   / thinking of hydraulic sliding tines on forks? #10
Looks good. :thumbsup:
What is this on the left fork?
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
48in Forklift Safety Basket (A56857)
48in Forklift...
1250 (A58374)
1250 (A58374)
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
