Rear Remotes - Planning stages, need advice
/ Rear Remotes - Planning stages, need advice #91
I don't think so. I don't see anything in my catalog. No good way to have a nut on there to tighten things up. What about using ORB QDs?
/ Rear Remotes - Planning stages, need advice #92
Not sure what those are... Seems like all hoses come with straight ends .. if I could find pre made jic hoses with 90's That would work too... Trying to avoid too many fittings :)
/ Rear Remotes - Planning stages, need advice #93
I can get you whatever you need, probably for less $$ than any of your local shops. For the most part, most premade hoses have straight ends and are not the right lengths. Actually a 90 degree fitting and a straight hose fitting is less money than a 90 degree hose fitting. Usually don't take up any more room either. I agree fewer fittings are nicer, but not always available or practical.;)
/ Rear Remotes - Planning stages, need advice #94
It's going to be around 150-170 on surplus centers website... Can I give you a call tonight or tomorrow..I would like to order ASAP I was going to order on surplus centers website tonight but I'll hold off to see what your hoses would cost.
/ Rear Remotes - Planning stages, need advice #95
Email me over here with the sizes that you want and I will price them out tomorrow. Usually ship 1-2 days. Did that price including shipping? You get these from me and you should have them by the end of the week. ;)
/ Rear Remotes - Planning stages, need advice #96
Honestly I haven't got that far yet so I'm not sure about shipping.... My grapple should be here Thursday so I'd love to get them by Thursday or Friday... Ill email you in a few min.
/ Rear Remotes - Planning stages, need advice #97
I can't speak for number9L and he has not been on the forum for a couple of weeks, but the valve set that he bought ended up with internal leakage and I am pretty sure that it was considered within spec. :eek: So ultimately he has hydraulic cylinders that were leaking down at a pretty good rate. :( So you might want to consider a different brand of valve. :confused3: It's to bad he ended up with those problems, he did do an excellent installation. Hopefully he will come back and get us an update of how things are now.;)
Just had a private message question about number9L's valve. Thought that I would clarify that he bought his control valve from another source and that it is a different brand valve than what I sell. ;)
/ Rear Remotes - Planning stages, need advice #98
I can however blame you for the quality of my valve on my install ;) which more or less started out to copy Number9L's install (except for the part where the valve sucks, then resulting hose length changes). Hopefully we'll see if there is blame or celebration on valve quality & leak down here in the next few days.
/ Rear Remotes - Planning stages, need advice #99
Let us know, good or bad. :thumbsup:
/ Rear Remotes - Planning stages, need advice #100
Blame the manufacturer.
You can't blame people for the parts you install.
We can only advise here and hope the things we sell are up to specs.
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
1990 TRAILMASTER CRUDE TRAILER (A60736)
1990 TRAILMASTER...
2019 Kubota SVL75-2 (A60462)
2019 Kubota...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2023 FORD F-150 (A60736)
2023 FORD F-150...
