My 8n
   / My 8n #1
Kuskojim
Aniak ak
8n Ford
Just bought 1949 ford 8n w back blade , dirt scoop , 4"rototiller, disk and 3 point boom for 1000.00 dollars in bush Alaska . When river freezes plan to move it to my property that is 3 miles up the Aniak river
   / My 8n
Want to convert my 8n to 12 volt any ideas
   / My 8n #5
I replaced faulty generators many years ago on tractors that I owned. It was real simple, although I have forgotten the exact details. I started with a used GM alternator. modified the attachment brackets to suit. At that time the GM alternators had a battery connection wire and a 2 wire harness plug. This is what I don't quite remember. One wire went back to the amp/volt meter (battery wire) and the other two ( harness pair??) were twined together. IIRC the pair that got twined together had to be foot or more in length. All that I know for sure is that it worked for many years. I am sure there is someone here that has done this as well and can straighten out the details. This may seem obvious and you may already know but the battery has to be changed to a 12V. Watch out for whether or not it is negative grounded. Good luck.
   / My 8n #9
soundguy can explain more on the 8n stuff for you. You could try pm'ing him.
2015 CATERPILLAR 279D SKID STEER (A51242)
2015 CATERPILLAR...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
Category 3 Quick Hitch (A50514)
Category 3 Quick...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
