SKID STEER QUESTIONS
/ SKID STEER QUESTIONS #1
Bootstrap
Member
Texas
john deere 4020
Interested in a skid steer for ranch work. Brush clearing, post holes, dirt work, loading round bales of hay will be what its used for. I want a cab for protection from Bees when clearing brush and tracks. Our property is sandy, I assume tracks would be better. Any advice as to what models to look for? Horsepower? Brand of skid steer? How many hours on a machine like are considered rebuild time? My Uncle just bought a new John Deere and it works very nice. Other than that I have no experience with Skid Steers.
/ SKID STEER QUESTIONS #2
I wouldn't want a tracked machine on my farm. I have slip on tracks for muddy situations. They work great. Stumps and rocks are **** on full time tracks. I have a mini-ex with rubber tracks at work and you have to be real careful where you go with it. Just my 2 pennys.
/ SKID STEER QUESTIONS #3
A rubber tracked machine (CTL) is higher priced and costs more to maintain (most people say about $10 PER HOUR operating-maintenance) cost. The undercarriage usually needs major maintenance at 2-3000 hours ($10-15K), plus the cost of replacing tracks every 1000-1500 hours. A regular skid steer with over the tires (OTT) tracks is a more economical solution.
You might want to browse the skid steer forum at heavyequipmentforums.com for opinions of different brands.
If you are going to be loading round bales, lift capacity- tipping load is probably more important than horsepower (but the two are related.)
The other thing to consider is dealer support, either for maintenance work, or for parts.
I bought a JD325 for use on the farm. That was the smallest one I could find with the joystick controls I needed. I've been very happy with it but I can't really do any comparison since it's the only one I've operated other than a demo JCB. I would not recommend a JCB.
/ SKID STEER QUESTIONS #4
I have a cat 246. It started life as a tire machine and using it plowing snow, gravel road grading and other general use chores. I get about 300 hours out of a set of tires. (1000.00) The tires are useless in mud and forget about loose sandy conditions. This past spring I bought a set of 18" Loegering bolt on tracks. Basically remove the tires and bolt on a entire track system to the lugs. The ride is noticeably harder, but the stability and traction is 100x better. The cat 247 has a ASV track system that actually works like suspension and is the best ride quality in the market. Bobcat,Kubota,Deere, all have a rigid undercarrage that tend to beat you up on hard ground. If properly maintained, skid steers can go several thousands of hours.
/ SKID STEER QUESTIONS #5
I recommend a compact telehandler. 4WD 4W steer. It is a GADA machine (go anywhere do anything). :D
A 5x6 round bale.
The out front 7' brush hog.
The out front 6' box blade on a tilt-tach.
Installing a cattle guard.
More in this thread: http://www.tractorbynet.com/forums/...t/160568-compact-telehandler.html#post3243370
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
ALUMINUM STATIONARY LOUVER (A64281)
ALUMINUM...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A64280)
2006 FORD F-450...
