What is this lever?
/ What is this lever? #1
Hammer Head
Lock Haven, PA
Kubota L3800 HST, Scag Tiger Cat
Just received my new L3800HST yesterday. my Son noticed a lever down near (behind) the brake release lever.
I could not find anything in the owners manual, is it a compression release?
/ What is this lever? #2
If the lever matches the brake SET lever and is to the left of the brake SET lever, it is probably the Cruise Control engagement.
This is a dealer installed kit on Kubotas, or at least it is a kit installation my B3300SU.
/ What is this lever? #3
A photo of the lever would be a big help.
/ What is this lever? #5
Hm... there is no brake release lever on a L3800hst. There is a brake set lever. but there is no lever behind it. The brakes are released by pressing the brake pedals to allow the set lever ratchet to release. on a DT version there is a PTO lever near where you are indicating, but yours is an HST and the PTO engagement lever is is up high on the right.. The differential lock lever on an HST model is on the left on the other side of the transmission tunnel... That is all I can think of on the floor on your model other than the brake pedals, and the HST treadle pedal..I give up..There is no compression release.. We need a picture of what you are calling a lever.???
James K0UA
/ What is this lever? #6
Ejection Seat?
/ What is this lever? #7
Ejection Seat?
Yeah, I am wracking the old gourd here, and I cannot think of a thing where he is indicating. Maybe someone installed that ejection seat:D
/ What is this lever? #8
I have one and found it the second Day.
/ What is this lever? #9
OMG.. :shocked: It's called the "Speed set device"
/ What is this lever? #10
Dont know the new ones but sounds like the fuel cutoff knob placement on our Kub Ls
/ What is this lever? #11
Nah, all the newer Kubota's have a fuel shut off solenoid on the injector pump.
/ What is this lever? #12
Nope, that a big mechanical lever on the left side of the operators hip, right by the range selector.
/ What is this lever? #13
Its a mystery, inside of an enigma, wrapped in a riddle.:confused3:
/ What is this lever? #14
The only leaver I have down by my right foot close to the brakes it the PTO leaver?
/ What is this lever? #15
So do our Ls ... Perhaps the knob was a short tern holdover from prior models on which it was not redundant. Our B9200 requires its use.
larry
My son has the tractor right now. He took it as soon as it arrived. I will stop and get a photo of it or a closer look.
Didn't mean to react so quickly with the question, we were just curious. It may just be the ejection seat leaver for the unwanted users!!
After closer observation I discovered that the lever is the throttle linkage. The hole that I thought should have some type of knob must be for the foot throttle to connect to for the MT model.
Sorry for the quick reaction to question it and thanks for the response from all.
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
3Pt Bale Carrier (A66408)
3Pt Bale Carrier...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
