Stihl MS250 plunge cutting stumps
   / Stihl MS250 plunge cutting stumps #11
Are you using wedges to keep the kerf open? You ought to use a longer bar/chain for the size stumps you're cutting too, or a bigger saw. Whatever saw/bar/chain you use verify the bar is straight, the chain groove is not pinched and the oiler is not clogged.
The trees were on a common property line and died about two years after my former neigbor limbed them to the top... his side and a lot on my side... I started a thread back then saying what I found when I came home one night after the neighbor asked to cut a few branches... ones he pointed out and I said sure.
Had a tree service take them down... $1,800 to cut leaving the rounds on my side.
Tree service left them about 12" above grade on a downslope... they were in the way of getting forklift delivery of concrete and retaining wall blocks.
I mentioned to my new neighbor taking out the stumps with the backhoe and he did not like the idea of distrubing anything on his side... a sewer main serving over a 100 homes runs right down the property too... so that was enough reason not to use the TLB... By the way, the neighbor that killed the trees a couple of years back walked away from the property and left the country too...
Stump grinder was my choice... after coming home without it... I just decided to use my saw... I was determined now...
No... didn't use any wedges... did not really think about it because there was only about 12" of trunk on top of the cut...
Saw has only a couple of tanks of fuel since new and up to that time has been babied.... looked new.
   / Stihl MS250 plunge cutting stumps #14
Well it's finished for sure. As soon as you overheat the chain you might as well throw it away. Send it to me, I'll dispose of it.
A Stihl 250 should be able to run at WOT till you get smoke coming from the stump. The last stump I cut up I was lazy, so I put a 41" bar on one of my 660's and just ground into it. That way II didn't have to bend over.
On a related note...
I imagine over time a small sink hole or depression will form as what's left of the pine decomposes and I will keep adding dirt/gravel as it does...
   / Stihl MS250 plunge cutting stumps #16
my pine stumps rotted out in about 2 yrs. Yes, I had to keep adding dirt to the hole as the stump continued to decompose
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
