X740 fuel filter change
/ X740 fuel filter change #1
950Tourer
SW Ohio
John Deere X740
As the title suggests, I changed the fuel filter on my X740 this weekend. The owner's manual states "Turn locking collar (B) counterclockwise to remove bowl (C)."
That must be if you are laying on the ground looking up at it. But if you are standing above it, like I was, you need to turn it clockwise to remove the bowl. Just thought it was interesting that they had it backwards. Although, maybe I had it backwards since I was standing. :laughing:
Thought I would pass it on.
/ X740 fuel filter change #2
Any tightening / loosening instructions I have read are always from the perspective of looking at the end being loosened. A nut/bolt would also turn backwards if viewed from above. Did you change the actual fuel filter or clean/replace the screen in the water separator? From the description it sounds like you were working with the water separator. The fuel filter is a black canister that looks almost identical to the oil filter.
My 2720 manual was very confusing as in the section about changing the fuel filter they only showed a photo of the water separator and only gave instructions for removing the bowl. Only the technical manual showed the actual fuel filter replacement procedure.
/ X740 fuel filter change #3
The x740 is like my x748...no black spin on filter. The paper filter is in the water separator.
/ X740 fuel filter change #4
Anybody had a problem with the fuel coming thru after filter change?
I had a little air get in my lines, but after a couple cranks it cleared.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
16ft Southland enclosed trailer (A64047)
16ft Southland...
Informational Lot - Financing (A63118)
Informational Lot...
2017 INTERNATIONAL 4300 4X2 26FT CDL REQUIRED BOX TRUCK (A59910)
2017 INTERNATIONAL...
2012 International Prostar (A63118)
2012 International...
