Ford 2600 (1976) Steering Column Leakage
   / Ford 2600 (1976) Steering Column Leakage #1
Taylodp
Pass Christian, Ms
Ford 2600
I just purchased a Ford 2600 (1976 model year) diesel tractor. It is leaking steering fluid out of the top of the steering column just below the steering wheel. Has anyone had this problem and know what the repair is?
   / Ford 2600 (1976) Steering Column Leakage #2
First off, Welcome to TBN!
You should post this question in the Ford tractors section, you will get plenty of good advice there I promise! :thumbsup:
Sorry, I am new to this forum and could not find any other place to post the question. Thanks for the "heads up".
   / Ford 2600 (1976) Steering Column Leakage #5
No worries. I just know that if you go there, you will find what you need!
   / Ford 2600 (1976) Steering Column Leakage #6
Welcome to TractorByNet!
I moved your thread to the Ford/New Holland Owning & Operating forum. :)
   / Ford 2600 (1976) Steering Column Leakage #8
lookup user Ultradog. He's practically an expert on those ford power steering systems. He can give you a plya by play to replace that top seal.
71060 (A49346)
71060 (A49346)
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2008 FORD F-750 (A50854)
2008 FORD F-750...
