Aftermarket fuel filter
/ Aftermarket fuel filter #1
datop
Rush CO
Kioti DK45SC, Fordson Super Major, Ford 1220, Farmall Super C
Is there an aftermarket fuel filter (NAPA,Wix) for a 2008 DK45S?
The nearest dealer is 200 miles away.
Thanks
/ Aftermarket fuel filter #2
Thanks
Try these people for parts--http://www.michiganironandequip.com/
/ Aftermarket fuel filter #3
I generally use Wix or NAPA (same filter with NAPA label). Amazon sells fuel filters if you need mail order.
Here's a list of all cross references
Product Type Fuel Cartridge
Product Height 3.5"
Product I.D. Closed (Top) .79" (Bottom)
Product O.D. 1.97"
AC-DELCO TP1374
BALDWIN PF717
CARQUEST 86507
CHAMP L549F
DONALDSON P502161
FLEETGUARD FF5103
FORD SBA130366060
Fram C10517
HASTINGS FF882
HENGST E77KP
INTERCONTINENTAL AUTO PARTS ALG-7531
ISEKI 151310231100
ISEKI 151310232900
JOHN DEERE T111383
KOMATSU YM129100-55650
KRALINATOR F680
KUBOTA 15521-43160
LUBER-FINER L549F
LUBER-FINER L5603F
MAHLE KX185
MASSEY-FERGUSON 3702815-M1
MELROE 6695912
MITSUBISHI MM433093
NAPA 3507
NEW HOLLAND SBA130366060
PUROLATOR F54557
SOFIMA S6681N
UFI 26.681.00
WIX 33507
YANMAR 129100-55650
Enjoy;
SimS
SimS,
Thanks for the reply. These all seem to be cartridge-type filters. My filter is a spin on type. Am I missing something? I don't want to remove the filter until I have a replacement on hand.
/ Aftermarket fuel filter #5
Datop, why cant the dealer send you a couple of filters in the mail? Probably have them inside a week.
/ Aftermarket fuel filter #6
NAPA has never failed to find an aftermarket filter for me. They have cross reference charts by other part numbers and by engine make and model #. Fuel filters are generic so OEM parts are not a must do.
Ron
/ Aftermarket fuel filter #7
If you can find an engine code, try plugging that into the Wix search engine. By your model, it does come up with 33507.
(Select Off-Highway Equipment, then Kioti. After that you can pick Model# or Engine Code.
WIX Filters - Products Catalog by Application
Rgds, D.
/ Aftermarket fuel filter #8
If you find an after market for a Kioti please post, so far wix does not list one neither does napa
/ Aftermarket fuel filter #10
sorry my bad I misread the original question, thought it was for hydraulic filter. That is the one I have been searching for for 3 years.
/ Aftermarket fuel filter #12
Went to NAPA when I did my 400 hr change, they just scratched their head, well by that time I had went to O'Reilly's and had everything but one Hydro filter figured out in Wix brand. O'Reilly's was a little more on top of it than NAPA. Just couldn't find one of the Hydro Trans Filters, air, fuel, oil and one of the Hydro filters was accessible, so I just ordered the kit that had them all and saved like $30.
/ Aftermarket fuel filter #13
Where did you get a Kit?
/ Aftermarket fuel filter #14
You know I don't remember, I thought it was farmparts4less.com, I think I bought the Hydros (seems the T4260-38125 was the hard to find one (lager one), not the T2195-38031), air and fuel through there and oil filter at Walmart, but can't find the history in the browser, I usually clear history every once in a while not to mention I install a new openSUSE Linux Operating System every six months or so depending on a new release's time frame, I do backups but not of browser history. Will look and see if I kept receipt/s, but not sure if I did that either. I kind of had lots of water flow under the bridge since then. If I find the receipts in the shop I will post them up.
Air -- Fram CA9248
Oil -- PH3593a
Fuel -- 76KD-10331
Hydro (small) -- T2195-38031
Hydro (Large) -- T4260-38125
Hope this helps a CK20 owner out.
/ Aftermarket fuel filter #15
I, also have found all of the filters in aftermarket versions except the hydraulic filters. Researching the hydraulic filter, I found it is a suction filter on the smaller tractors. In a suction filter setup, the oil is sucked by the hydraulic oil pump from the sump, through the filter, to the pump, and on. The filter must be specific for this type setup. Just because it will screw on does not mean it will work. I have not looked into the larger tractors, but guess they are setup the same. Having said that, I think someone is making the filter for Kioti. Most equipment manufactures do not make filters. They sub them out.
Napa
Part-----------Part No.-------Engine
Air Filter------6449-----------CK20S w / Kioti 3C100LW (1.0L) Engine
Fuel Filter-----3389----------CK20S w / Kioti 3C100LW (1.0L) Engine
Oil Filter------1334231-------CK20S w / Kioti 3C100LW (1.0L) Engine
BOSCH makes a heavy duty engine oil filter "Distance Plus" Part# D3312. It is built much better than the average oil filter, and you can find them at your local parts store/ Walmart.Cost about $11. The filter is heavier to the touch and is rated very high.
/ Aftermarket fuel filter #16
This is what I found when cross-referencing through Wix
T426038125- This is a valid competitive part number and there is no replacement at this time.
They acknowledge the filter exists, but do not make it.
/ Aftermarket fuel filter #17
Yep, what I was indicating when I said (Large) hard to find one.
Don't know why you are so NAPAheaded, you must have some reason, there are other places to buy besides NAPA you know. :confused3: :)
/ Aftermarket fuel filter #18
It is funny you say that! I own AutoZone stock. No affiliation with NAPA. :drink: I just like their products and my local guys.
/ Aftermarket fuel filter #19
we need a Sticky with cross reference filter for each model... moderator in the thread ? ;)
/ Aftermarket fuel filter #20
What is the Kioti number for the filter?
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
1996 International 4800 Bucket Truck, VIN # 1HTSEAAN6TH399113 (A65563)
1996 International...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
Knight Verti-Maxx 5032 Feed Mixer Wagon (A66408)
Knight Verti-Maxx...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
