Bench vise - machined steel, not cast, 4" to 6" range
   / Bench vise - machined steel, not cast, 4" to 6" range
Both Yost and Wilton are very good vises. I would lean toward Wilton in some applications due to the enclosed clamp screw. For other applications I would lean toward the Yost. I have both in a Wilton C2 and a Yost 33C. Great American Iron. The Yost is made from 65,000 psi ductile iron.
Even the new products are very good.
Thanks for the input, also new vs. old comments appreciated.
Rgds, D.
I don't think I have ever seen a machined steel vise. I assume you would want a cast steel vise as opposed to a cheap cast iron one. Wilton still makes high dollar but good vises.
That is a good way to summarize it Gary.
In the areas of material science that I know, I usually get the terminology right, so the perceived confusion was real.
Stumbling around this end of metal alchemy on my own didn't seem like a good idea, so I decided to check-in with the TBN braintrust.
Thanks again all. :thumbsup:
Rgds, D.
Google Brockhaus Heuer Vise. You can order direct from Germany on ebay.
HEUER Vice - Brockhaus Heuer - schraubstock.de
Thanks. The forged offerings listed in this thread will give my friend some options in terms of jaw profile.
It's great to see that high quality products are still being produced domestically, and elsewhere. In other product areas I have been personally frustrated by the prevalence of cheap junk - in the case I'm thinking of I eventually found what I was after, but it was a bit of a battle getting there.
Rgds, D.
   / Bench vise - machined steel, not cast, 4" to 6" range #15
Just remember a Vise is not an Anvil!!!
   / Bench vise - machined steel, not cast, 4" to 6" range #16
Unless it's made as one. I just bought one out of an antique store --patent 1895...that is steel vs. cast iron...and has an anvil tip on the back end of it. Also the non-movable jaw ...is movable...It has a spring under it that when you push down on the jaw it can slip back along the flat anvil top catching teeth along the way to where you want it. It will open to 14". I spent a lot on it. I was thinking Wilton but although they are made somewhat here....the base / movable jaw is cast iron from overseas (china?). They were featured on the tv show "how it's made".
Just curious (it would take me a crazy amount of time to track one of those down, even with big money to play with), if you have any pics, pls post - that sounds like a neat design.
Rgds, D.
   / Bench vise - machined steel, not cast, 4" to 6" range #18
Rgds, D.
here it is ...I plan on eventually mounting it to 1/2" plate on a 2" receiver thence onto my welding table that I hope to build when I get a new welder. I lost my old one to flood and it just hasn't been a priority. We moved and needed to build a new house and all. They wanted too much $$ for this and I let it sit in that shop for nearly a year before I finally broke down and paid them nearly what they were asking. They weren't in a hurry to sell it. They knew they'd eventually find some fool to buy it.....and did.
That is a cool design.
Supply and Demand - until somebody like Jay Leno decides to put these back into production, hen's teeth are more common. You can always get more money :2cents: :)
That depth alone is worth a premium, at least to me.
Rgds, D.
   / Bench vise - machined steel, not cast, 4" to 6" range #20
Older and made in the UK was likely a Record (there are others, but they were by far the most common). Cant speak to the quality of the Irwin ones, but generally Irwin and quality arent in the same sentence. Im not a real fan of Irwin, most of their stuff is overseas origin. They basically destroyed ViseGrips when they offshored them.
For a premium "mil-spec" vise, its hard to beat a Wilton Machinist bullet. They are the best vise you can readily get today IMHO. Very far from cheap though, $1000+ for one of any size.
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
