Tires Ford tires
   / Ford tires #1
Tipptop
Georgia
Ford B 3000
Hi guys. I have an old Ford 3000 I use to cut the grass in my back field. It has a flat front tire from dry rot. How much should I expect to pay for two front replacement tires?It's a 2WD. Thanks for your help.
   / Ford tires #2
$142.00 for pair of 6.0-16 3 ribs on ebay right now. Probably $95 each at TSC or tire place. Dont forget $10/15 per for tube and $10 per for mounting.
Edit: I reread your earlier post and I still stand by my earlier suggestion of taking it to several independent car tire guys and asking for a used truck tire of similar width/height. If you can, probably wont be out more than $40 total
I hate to sound like a safety guy, but remember the front axle isnt solid like a car, so jack and block from near the tire on the axle, NOT the center front of the tractor,
   / Ford tires
$40? Really. Wow! Thx so much for the info. I'm definitely gonna try that. I'm not at home now, but do u know what size front tires are on a ford 3000 typically?
   / Ford tires
Oh ok I just saw your earlier post about eBay and tire size.
   / Ford tires #5
Factory should be 5.50-16, but thats are rare size now. 6.00-16 are a total of 1" taller, and 0.5" wider, and work fine as well. In a truck or trailer tire, 205/75r16 or 205/75d16 also fit. If you go to a tire shop (not a major chain or retail store that does tires) bring your tire and rim with you and ask them for a used tire of roughly the same size. Yours should be ~27" tall, and pretty much anything that fits on your rim from 26" to 29" tall should work fine. More plys are better or a higher load code (c is better than b, d is better than c, ect). If you can find load-D 205/75r16 trailer tires used, in fair shape, or anything close (must be 16") you'll be back in business.
   / Ford tires
Thank u so much. A friend of mine knows someone who sells used tires so I'm gonna go that route first. I'll let u know what I find.
   / Ford tires #7
Check with your local Farmer's Co-Op, or local tire dealers. Those tires are not terribly expensive. You should be able to have a new set mounted, tubes included, for around $200.
Paul is correct, you'll need to ask for the 6.00-16 size. The smaller tire is obsolete.
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
John Deere Fenders (A56469)
John Deere Fenders...
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
2013 Ford F-550 4x4 10ft. Flatbed Truck (A55852)
2013 Ford F-550...
