Dealer Yanmar ym2010
/ Yanmar ym2010 #1
4man
Member
Magnolia Texas
Farmtrac DTC360 w/FEL
Hello and thanks for all the information available on this forum, as I have posted before I'm almost 63 years young and have never owned or operated a tractor of any kind.(not counting driving an old model ford,and that was in 1962, from where my dad bought it to our home 30 miles away because we didn't have a trailer) I have been looking-searching and reading about what to buy for about 6 months and have almost made the decision to buy a YM2010. Problem is the only dealers I can find are 2 located here in Texas. One is only about 50 miles away and the other is about 350 miles away from my home close to Houston. Both of these dealers sell Yanmars that have been reconditioned in Vietnam and use the loaders with the big blue V on the arms of the loaders. The one nearby has a (YM 2010 is a 24HP 3cyl. Diesel 4WD Tractor that is equipped with a new Front End Loader) with the shredder and box blade $850 and $495 as add on plus tax.. Question should I look at the used Kubotas and John Deere's and the Ford/New Holland because all I've read clearly indicates to stay away from these from Vietnam and because of price I would rather buy used than buy a Chinese tractor.
I'm really ready to make a decision and there are many what seem to be good deals on Craigs List, but I would much rather have a reconditioned that has a warranty(more than 90 days) than some one else's problem. Thanks in advance for your help and advice.
/ Yanmar ym2010 #2
My dad put me on a tractor when I was still in elementary school. Fast forward 50 plus years and a couple of career changes. I now own a Kubota and love driving my tractor. Do you really want used?? Used tractors hold their value very well. For just a bit more money you could own new. For me new was a no brainer because I could buy with no money down and 0% interest. But I digress. Since you have never owned or operated a tractor my suggestion is to buy a tractor that has the HST transmission. Push a pedal with your toe to go forward, push a pedal with your heel to go backward. No shifting manual gears. In certain situations that is far safer than gear. Works really great when mowing. Your purchase decision should also include how you are going to use the tractor. Mowing? Gardening? Dirt work? I find a front end loader absolutely indespensible. Also make sure you buy enough horsepower!!
/ Yanmar ym2010 #3
as stated above,new is very nice and easy to acquire however.... used can be a lot less expensive, thats considering you can live with repairs the unit may need,thats the big issue. If you are handy and dont mind the occassional headache that comes with used you can definetly save some green. I am sure you will get a mixed reply on this topic......
Good luck w your search, Most smaller tractor brands including Yanmar are hard working,reliable tractors and will hold there value pretty well
/ Yanmar ym2010 #4
Budget was a big deternining factor for me. That is the reason I went with a vn refurbished ym2002d from LCI in Wills Point, Tx. They have now gone under. I did not do any research before buying. Didn't even know what grey market meant. Short story is over $2000 later I now have a reliable tractor. Much of that came out of my pocket. I really consider myself the exception rather than the rule. Many vn buyers purchases have turned out good.
What makes these old Yanmars so attractive is their simplicity and what they are capable of with their small size. Just remember your model was manufactured in 1980-81 making it 30+ years old.
After proof reading this no doubt it would lead anyone to run from the vn tractors. My tractor had a 90 day warranty which wasn't long enough. If I had it to do over again and could get a 1 year warranty as some are advertising I would probably do it again. A lot would have to do with the reputation and research on the dealer.
/ Yanmar ym2010 #5
used tractors hold value but i paid $4k for my 24hp yanmar, way less than anew tractor. & did get a vn but knowing everything i know i would of got a fredericks model for the same price. but at this point it not only does not matter cause its been 3 years but more so nothing happened to my vn model that the dealer did not fix. things like volt regulator and bad 3pt valve and leaky radiator. all fixed under warrenty. tractor has done all i asked and more. there are plenty of us that have done ok with vn models, but the fredericks or other us reconditioned ones are not without fault. i know 2 members on here with worse problems than i have that got their tractors reconed her in the US fron 2 diff dealers. Just remember its something your gonna have to work on if u get a used 30 plus year old tractor. but if ur planning on going out to buy a us reconed model with powershift and a new loader there is no question in my mind id buy a used nh or jd or maybe look at a new kioti or manihandra.
/ Yanmar ym2010 #6
My YM2210D is a VN tractor that needed several repairs. these repairs were inexpensive but time consuming. The biggest drawback was that the engine was not original to that tractor and was mis-identified by it's model designation tag. It was later determined that my engine was from a smaller and older tractor but still bolted up the same. Now that I know what I have, it works fine. The dishonesty of the importer is disheartening.
/ Yanmar ym2010 #8
Is this the one that had a (earlier) YM1900 engine substituted?
My YM2210D had an early 2TR20 engine with the 2T90 ID tag on the engine. I forget what tractor originally used that engine.
A tag on the fuel pump had the correct tag (2TR20) on it but it was painted over. My engine was originally black but was repainted with the 2T90 green. To further confuse the issue, my fuel pump used banjo bolts on the fuel lines. The early, 2TR20, engines used banjo bolts. Fuel pumps on the later 2TR20 engines used hose end fittings that screwed directly into the pump.
/ Yanmar ym2010 #9
That must be the one I was thinking of.
2TR20 was early - very early - YM2000. The green one.
That's outright fraud to rivet a 2T90 id plate onto it.
/ Yanmar ym2010 #10
No doubt, but it was still a bargain and it is quite reliable.
/ Yanmar ym2010 #11
Shame on them........VN tractors..... Like opening a box of chocolates. You never know what your going to get ! Well, it's running and if your happy. I guess that's all that counts !
/ Yanmar ym2010 #12
Sounds like you got fair value for your money then.
I wish I had a YM2210D but I've never seen one near here priced reasonably. I see one on CL for $7500 with loader, claimed 814 hours and "REFERBISHED INSIDE AND OUT" (sic). I'm still waiting - after several years - to see one for what I want to pay.
/ Yanmar ym2010 #13
a guy I know sold his VN 2210 for im sure less than that but not sure. He had it about a year and it really was not what he wanted. His hrdros were so good he could leave the BH and bucket up for weeks and would not leak down any noticeable amount
/ Yanmar ym2010 #14
I have learned that whenever the word, Refurbished, is used in in connection with Yanmar tractors, the word, Refurbished, was substituted for, Salvaged. Basicly they replaced any noticeably broken component with that part salvaged from another tractor. Also, the hours on the tachometer mean absolutely nothing. Mine had less than 200 hours on it. The tachometer is just as likely one of the items that was salvaged from another tractor, if it was not turned back. That so many of these things are reliable is a testament to Yanmar for their original quality. I believe I paid $7200 for mine with new back tires, a new FEL and box scraper about 6 years ago.
/ Yanmar ym2010 #15
I know this thread has a little age on it but hopefully some of you are still reading the mail. I am curious as the to tone of my YM2210. I know a lot of guys have asked about the serious knock of the 2T90 (the Yanmar Hammer) but I am a little concerned with reference to the slight skip when I rev the engine. It's not a serious miss but if it were a Chevy, I would say it's skipping. Does any of you experience the same thing? I also noticed that the tach needle jumps with the sound of the miss. There is no white smoke which usually accompanies a misfire, but being a newbie to the 2 cylinder diesel I thought I would ask some of you experienced guys. Oh, by the way, I have bleed the fuel system in an effort to purge the air but it still runs the same. Any comments will be deeply appreciated.
/ Yanmar ym2010 #16
I dont have anything. Mine sometimes at a certain rpm has what in the exhaust sounds like a miss?? Dont think it is, the tractor is smooth reving and everything i just think its how it comes out???
/ Yanmar ym2010 #17
Thanks for that info. I kinda feel the same, it's just how it is supposed to sound. Now I need to head out to the tractor to check my warning lights. Need to do some troubleshooting because none are lighting up. I just bought this tractor and so far so good. Just need to make sure that the seller didn't disconnect the lights to hide a problem.
/ Yanmar ym2010 #18
Another question with reference to warning lights. I checked my lights yesterday and had connection problem which I was able to fix. My question now has to do with the temp light and how do I test it. I removed the wire from the temp sensor (or sender) and tested the wire with my power probe and the bulb came on. I replaced the wire and used a heat gun on the sensor connection and the light never came on. Is there another way I can test the sending unit to make sure it's is functioning correctly?
/ Yanmar ym2010 #19
Take it out, put it and a temp gauge in a pan of water and bring it to whatever temperature does or doesn't activate it using an ohm meter. Will that work?? :confused:
/ Yanmar ym2010 #20
You may need to use a water-antifreeze solution, because the warning light may not come on until it is above the boiling point of pure water. (antifreeze raises the boiling point)
K
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Fertilizer Openers (A65640)
Fertilizer Openers...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
King Kutter 5' 3-Pt Gear Driven Rotary Tiller (A66285)
King Kutter 5'...
10ft Cultivator (A65579)
10ft Cultivator...
