broke it
/ broke it #1
allen6634
hawesville
600 ford
i borrowed my neibors tractor yesterday so i could bush hogg my field , i the drive shaft broke , so i am wanting to fix it, it is the square typ are there any shafts available?
/ broke it #2
tractor supply should have what you need
/ broke it #3
I assume you are talking about the PTO shaft that drives the bush hog and not the tractors dive shaft. If you broke the tractors drive shaft good luck with that one :eek: If its the PTO shaft and if it was me (after borrowing it) I would go a buy a new shaft for the guy. :thumbsup: That would also be much safer than trying to repair it depending on what has broken.
/ broke it #4
That was quite a shock load to transfer to the PTO gear box area and the gear box on the rotary cutter.
/ broke it
well the tractor was barrowed not the hogg (that was mine) i was hoping to find a replacement shaft that connects to my hogg , i have old equipment (it fits my 600 very good) and i just bought the front part of this shaft ( this is the part that connects to the tractor) didn't see theother end of my shaft was hopping that maybe someone knows where i can find one
/ broke it
i agree untill my ford broke i was keepin my field clean ,i don't know how or where this chunk of wood came from, i have two brush piles that i am planning on burning when the time is right, my hog is slated for a rebuild next ,i hope i didn't damage anything in the gearbox .
/ broke it #7
I did the same thing earlier this year to my bush hog. TSC didn't have the correct replacement shaft so I hit up the ag dealer down the road. I was able to purchase the correct shaft and yoke for a whole lot less than a new pto assy would have cost. Be sure to take in the old parts for proper match up.
/ broke it
thanks i never thought about that i have checked out rual king they don't have any that i can use ( other buying a new shaft). i'll give the closest dealer a shot.
/ broke it #9
post a detailed pic of the damage
ps. what's wrong with the series 600 ford?
maybee we can help you with that too.
/ broke it
i will try and get my wife to take a pic with her phone, i don't have a cell nor do i want one, so pics are kinda tuff.
/ broke it #11
Buy a whole new shaft. Check out haytools.com and agrisupply.com Should be able to get a complete shaft for ~$120 or so.
Last I looked at TSC, they wanted almost $200 for 1/2 of a shaft.
Dont worry about length. (just make sure its long enough). Match up the ends and strength you need, and you can cut to length.
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
7061CFL (A64553)
7061CFL (A64553)
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2025 SZYMJ Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 SZYMJ...
KING 22 BLADE DISC HARROW, 3PT (A64278)
KING 22 BLADE DISC...
