Buying Advice Aged Inventory
/ Aged Inventory #1
erodriguez
Louisburg
JD 755
Hi,
Started looking at tractors to work 50 acres of pasture. I found a dealer with a 2009 "aged inventory" tractor sold with full manufacturer warranty, the unit has 3 hours on the meter. My concern is with what would go wrong in a tractor sitting around doing nothing for 4 years, what should be checked and what should be replaced? I figure fuel tank should at least be inspected and maybe drained. What about fuel filter, oil, oil filter? What can go wrong with the hydraulic system from sitting around?
Thanks
/ Aged Inventory #2
the tractor is fine.the dealer will put it in the shop an service it before delivery.if your that concerned about it talk to the dealer.
/ Aged Inventory #3
Is it a pretty good deal?
/ Aged Inventory #4
i dont know the tractor your looking at or the price of it.but i do know this they should make you a good price on it to get it off the lot.
/ Aged Inventory #5
What kind is it? Make sure you get a New Battery.
/ Aged Inventory #7
If it has been setting in the rain and sun for 4 years I'd want a very good deal! But I wouldn't worry about it being "aged"...
/ Aged Inventory #8
I bought mine several years ago as aged inventory. Got a sweet hot deal, more tractor than I was hoping for at a price waaaay below subpar units. Years in and zero issues!!!! Why not go for it?
Fluid flushes and filter changes, new battery, check all the rubber for rot. There should be some money from the manufacturer for you taking this one!
/ Aged Inventory
Thanks for the advice. It didn't dawn on me that the battery could be a problem - though it probably wouldn't have taken long to find out :) Its a long haul to go back to that dealer for things like that so it's better to know ahead of time. It seems like a pretty good deal - a little less than 8k off an MSRP of $25k
/ Aged Inventory #10
I hope that is a 2009 msrp price less the 8k. On a 25k tractor msrp I would expect a discount of about 18% on a "fresh" trractor which would be 20.5k Sounds as you getting an additional savings of 3.5k. Most tractors have gone up in price since 2009 too.
/ Aged Inventory #11
It might help with brand, HP, add-ons (FEL, attachments, implements, trailer), and list in 2009. For an example I received ~30% discount after a kick-back from the manufacturer on a package including an FEL and bucket.
/ Aged Inventory
Its a 2009 Bobcat CT445 with FEL and they are asking 18,800. Its quite a ways for me to go take a look at so I won't complete the deal until I've completed negotiations. I understand that Bobcat is getting out of the business so I will wind up with a white Kioti that I may never be able to sell, but I figure if I get a decade or more of service from it I would be happy. I think I've worked my way through the pros and cons and it should fulfill my foreseeable needs.
/ Aged Inventory #13
I would offer about $15,000 and might go to $16,000 maximum if it looked real good.
/ Aged Inventory #14
You want the 2nd Remote plus plough light and loaded tires. All new fluids and filters and make sure to look at all the soft stuff like seat accordion and covers.
/ Aged Inventory #15
FWIW, look at the used prices on the very same model. I might add a small premium to the used pricing as this has no true hours. Make the offer, in writing, as a cash deal (or already have your financing lined up and ready to go) with the dealership taking care of any items which might have gone bad from sitting (not too likely but you never know). I would do a very good look a the fuel lines and have them replaced if there is ANY signs of cracking. Drive the unit and put the FEL under load before accepting. Make sure there are NO leaks. Turn the unit off with the FEL and 3pt under a bit of load and see if they leak or if the units drop. Do not leave them under load for extended periods of time...
Kioti is average quality. If you are not working it like a dog (400-1000+ hour a year) it should last you more than a decade and it will retain some value. Parts should remain available as a Kioti.
IF I am not mistaken, the FEL will also take all of the Bobcat connections for skidsteers! This is a plus for you and increases the useability of the unit.
Sorry, just did a quick (VERY quick) market research and I would think $17-18K would be a good price for a complete CT445 with FEL and two rear remotes. Double check against a new LS for pricing. That is just me!
Verify my information above independently. I am not an expert and only farm as a hobby.
/ Aged Inventory #16
In addition to the almost zero hours, he will be getting full warranty That has to be worth a decent premium over the same aged with hours and no warranty. How does warranty work for machine no longer in production? Will he have to work with original dealer who he say's is far away? Can't take to Kioti place for warranty work. Definitely get new battery,
/ Aged Inventory #17
Not to get defensive simply because I own a Kioti, but I'm curious what makes you an expert in this area. My experience with Kioti is it's built more solid than most of the competition and is better equipped at a competitive price. The company has been around since the 40's and selling tractors in North America since the 80's. My decision when buying my previous tractor came down to a Farmall 35 or Kioti CK30 (or a L series Kubota), I chose the Kioti for price, features and specs. I have compared my current DK45 (the same tractor the OP is considering, only orange) to my friends Farmall 50 (or 55?). It has more features, is bigger and seems more rugged. I'm not bashing your Case, I'm pointing out some of us look at the same machines differently. I fail to see how you know the Kioti won't work as hard or last as long.
/ Aged Inventory #18
I think the dealer's asking price is in the ballpark. Anything more you may gain through negotiating is gravy.
/ Aged Inventory #19
I think the guy that said 15/16 was inline, for that price I'd consider it.
I wouldn't pay 18+ for a rig that's been sitting outside for four years.
To me it would be worth a couple thousand to have a new "fresh'' unweathered machine, I'm picky though.
Also I think that unit has the floor with the hump in the middle, vs the current Kioti DK flat floor.
Also the pics that I've seen of that year CT445 didn't have quick attach buckets on them.
Just some things I noticed taking a quick look on the web and you tube.
Good luck
/ Aged Inventory #20
I have not checked tractor prices in this size range in several years.
grm61 suggests that a "fresh" 45hp tractor could be had for $20,000 or so. What tractor brands are in that $20,000 price range with the Bobcat's horsepower and features?
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
JOHN DEERE FLEX PULL DISC (A63745)
JOHN DEERE FLEX...
