GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs
3 tires maybe.
4? No.
   / GM unveils new 6.2 1/2t specs #193
You're right.. Limited slip in the rear of mine.. So true.. Only 3
With a Super Duty, limited slip in the rear usually doesn't mean a whole lot. That's one complaint I have about my SD...the limited slip is next to worthless! The one in my '05 F150 worked MUCH better.
The Dana limited slips in the duallies is MUCH better than what the Sterling axle uses.
Make that a 2 wheel, 4 wheel drive burnout! Haha
   / GM unveils new 6.2 1/2t specs #195
Most of them have a e-locker now.
A LSD is okay in a street truck or car but the clutches go bad over time. You can also overpower a LSD and do a one wheel peel or under the right conditions it won't engage. Also a LSD does not divide the power 50/50.
Sent from my Samsung SPH-L710 using TractorByNet
   / GM unveils new 6.2 1/2t specs #196
A LSD is okay in a street truck or car but the clutches go bad over time. You can also overpower a LSD and do a one wheel peel. Also a LSD does not divide the power 50/50.
The e-locker is an option in the SD now, but yes, the PowerStroke just overpowers the LSD.
   / GM unveils new 6.2 1/2t specs #197
I prefer a limited slip in a street truck as well. I chose it over an e-locker when I ordered mine. When towing, you would have to push the elocker switch to take off on wet pavement. That would be a pain. I think they are safer also because if you need to move quick in an emergency, the limited slip would work and not the elocker.
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
