Problems Starting an Elecric Generator
/ Problems Starting an Elecric Generator #1
rpeter
Cumberland county Pennsylvania
Kubota B7800
I was just given a 13 HP Electric start Electric generator. The man that owned it said he always had trouble starting it. I find that it starts fine when it is cold. Start it cold it runs fine; turn it off wait 30 seconds; start it and it runs fine. However; if you start it and run it for say an hour....... then turn it off and you can not get it to start again......until it has completely cooled down. Anyone got any suggestions?
/ Problems Starting an Elecric Generator #2
I say Vapor lock on the gas or bad coil.
/ Problems Starting an Elecric Generator #3
Take your gas cap off. The vent may be plugged on the cap.
/ Problems Starting an Elecric Generator #4
What kind of unit is it?
Do you know what brand of engine it has?
Thanks for all the quick replies......
I had thought of a vapor lock but did not know what might be causing it.
This is a "Chicago Electric Generator". It is a Chinese manufacture sold by Harbor Freight. But hey it was free :D
The engine is Chinese ..... Lifan is the manufactures name
I will try " hot start with the gas cap off.
Thanks again.
/ Problems Starting an Elecric Generator #6
It's possible that you have an ignition problem. After you have run the generator for a while, shut it down and see if it will start. If it doesn't, pull the spark plug out and see if you are getting any spark.
/ Problems Starting an Elecric Generator #7
I concur. Do you know if it has an electronic ignition system? It sounds like the capacitor (condenser) or high tension coil is breaking down from just engine heat.
/ Problems Starting an Elecric Generator #8
You can also remove the air cleaner and shoot a little gasoline into the carburetor throat. If it runs for a few seconds on the gas you shot in, then gasoline is not getting to engine. If gas if getting to the carburetor (gas in bowl), then crud may be getting pulled up to block main jet.
Also check for spark as has already been suggested.
/ Problems Starting an Elecric Generator #9
Make sure the cooling fins are all clean. If it gets hot enough, when you shut it off, the gas in the carb starts to evaporate.
I tried leaving the gas cap off and that did not help. Looks like the next is to take off the air cleaner and then the spark plug.
Thanks again for the help!!
/ Problems Starting an Elecric Generator #11
Try a new spark plug. The plugs that come with those engines are junk. Its recommended on a brand new Chinese engine that you throw the plug away and replace it before you ever start it. They're that bad.
If its a resistor plug, they can actually be bad internally and affected by heat. Its worth a shot and a cheap fix if that was the problem.
Tried the spark plug and that was no help. Am having trouble finding anything to "insulate the gasline to keep it cool.
If it is the condenser how can I check that?
/ Problems Starting an Elecric Generator #13
I don't know a lot about Chinese engines but usually the ignition system is located behind the flywheel. That engine might have an old style ignition with a set of points and condensor or it might have an electronic ignition system.
/ Problems Starting an Elecric Generator #14
Is the gasoline getting hot? Beyond the point where it flashes into vapor? I seriously doubt it. You will have to remove the flywheel to expose the high tension ignition coil, contact points (if equipped) and capacitor (condenser). Be careful removing the flywheel so it doesn't get distorted. There may be puller bolt holes in it. Note: Don't use the puller bolt holes as jacking bolts, use the correct type of puller.
/ Problems Starting an Elecric Generator #15
Next time it will not start try this run some cold water on to the carb for two three minutes. If it starts it is not ignition and probably just vaporizing the gas in the carb.
/ Problems Starting an Elecric Generator #16
Darn. ...I was hoping this would have been solved by now. Im with the people saying its spark due to a heat affected component. Easy check ... See if the engine has spark when it wont start.
larry
/ Problems Starting an Elecric Generator #17
What??
/ Problems Starting an Elecric Generator #18
He should try things at random rather than in a systematic manner eliminating the easiest to detect causes 1st. :wink:
/ Problems Starting an Elecric Generator #19
The logic escapes me of pouring cold water on a cold engine, that's all. It's like carrying coal to Newcastle. Is this not just a simple one cylinder air cooled gasoline engine that can be replaced with a new one for about $150.? :licking:
/ Problems Starting an Elecric Generator #20
On the carb. Trying to see if its vapor lock. A non definitive test of an unlikely thing. ... Is it getting gas into the cyl, is there compression, is there a spark? [per OP - "There is no expedient to which a man will not resort to avoid the real labor of thinking."]
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
2014 International WorkStar 7400 T/A VacCon Combination Sewer Jetter Vacuum Truck (A61573)
2014 International...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
