How many of you wear helmets when running your side by side UTV?
   / How many of you wear helmets when running your side by side UTV? #31
Econo, nice pic and rig, that thing looks like a hoot to drive.
Hmmmm, any worry about a copperhead or watersnake getting in your shorts there??? :eek::dance1:
   / How many of you wear helmets when running your side by side UTV? #32
Lol! I guess the adrenaline left us blissfully ignorant about that!
It was a lot of fun to run around on, but I got rid of it. Not too much utility with that machine. The Gator is a much better mix of fun and work.
   / How many of you wear helmets when running your side by side UTV? #33
Always wear a helmet when I ride ATV. When we started using the Gator UTV a year ago, we did both wear helmets the first few times we went. Always wear seatbelts to of course, but now we have stopped the helmets. I figure there is a full roll cage, so if I am belted in I am probably OK, unless I get hit by a bigger vehicle. Then, so be it.
ONE COOL THING we started doing however, is using a 2-place intercomm and low cost aviation headsets, when traveling on the road with the UTV. Its cuts the wind, allows you to converse without yelling, and reduces noise of course. also, its cool to be able to talk at a low volume so people can't hear what you are saying. Last time I checked, headsets were available for under $50 each, and intercomms cost about twice that.
   / How many of you wear helmets when running your side by side UTV? #34
Jim, can you recommend an intercom brand / model to look into? This sounds like a good idea.
   / How many of you wear helmets when running your side by side UTV? #35
The intercomm I use is a DRE 201. The 201 is no longer manufactured. Now there is a stereo version:
Intercoms
DRE is fine quality stuff, maybe overkill for off-road.
A google search using the words "aviation 2-place portable intercomm" brings up many choices.
Pilot USA seems to be popular, and inexpensive...
Pilot USA Intercoms
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A55851)
1991 Grove RT740B...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
3pt Hay Spear (A56469)
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
