Security & Theft secondary kill switch
   / secondary kill switch #1
tervete
Member
Martintown, ON, Canada
JD 3320
Hi guys. I was thinking of installing a hidden kill switch on my JD3320 to deter theft. Does anyone know how?
Pauly
   / secondary kill switch #2
There are many ways to do this. You can put a cutoff switch on the battery cable, the hot wire to the key switch, the hot wire to the injection pump or in the wire going to activate the starter. Any one of these methods are effective as long as you can place the switch so it can't be easily found. You could just get in the habit of removing the fuse to the key switch also. This can be just as effective in deterring theft.
   / secondary kill switch #3
Another theft deterrent would be to turn the fuel off at the water separator.
   / secondary kill switch #4
There are several safety interlocks on my kubota - clutch, pto, the rocker pedal for forward/backward. I put the pto control on, then unplug the clutch switch and hide the wires. that makes two "kill switches" that would take a while to puzzle out. also park the thing in the middle of some trees so it cant be hauled out by a tow truck.
   / secondary kill switch #6
Many people just remove the key,,,
Seeing Kubota uses one key,not much of a deterrent.Battery switch may be the easiest to do,lots of people do it for their"classic"cars that are in storage.
   / secondary kill switch #7
One would think since new tractors cost as much as they do all tractor manufacturers could install an ignition switch with a key that not duplicated.
Thanks guys. I'll check out what Radio Shack for a switch.
Tx again.
   / secondary kill switch #10
You could remove the clutch pedal and take it to bed with you.
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
Tires (A50322)
Tires (A50322)
John Deer 625F Grain Platform (A50514)
John Deer 625F...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
