Comparison Comparing the JD. 5075 to Kubota M7060
   / Comparing the JD. 5075 to Kubota M7060 #1
john10
York, PA
Kubota M7060cab, RTV1100cab & John Deere F930
I am confused on which model compares to the Kubota M7060. The American made John Deere 5075M or the Indian made 5075E? The dealers are bias of course. I am thinking the Kubota is maybe in-between the M and the E? Can anyone straighten me out on this.
   / Comparing the JD. 5075 to Kubota M7060 #3
If you want to compare deluxe tractor to deluxe tractor, then it would be the 5075M. The John Deere E models are their economy models and I would imagine that the M Kubota's probably look better than the E Deere's. I doubt that can be said about the M Deere's though.
Good luck in your research. ;)
Thanks for the advise. I decided on the M7060. The John Deere dealer did not have a 5075M to compare, and with the price different it did not made sense any how. They are installing the stereo, air seat, tooth bar, 3 point hitch hyr. filling the tires with fluid and spreading them out, adding a second set of rear remotes.
   / Comparing the JD. 5075 to Kubota M7060 #5
Congrats and good luck with your new machine.
   / Comparing the JD. 5075 to Kubota M7060 #6
I am now in the process of making the same choice that you made last year. Are you happy with your decision and has the M7060 met your expectations?
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
CATERPILLAR 96" HANG ON WHEEL LOADER FORKS (A52709)
CATERPILLAR 96"...
JOHN DEERE (4) BOTTOM TURN PLOW (A58375)
JOHN DEERE (4)...
LANDPRIDE 5' ROTARY MOWER (A58375)
LANDPRIDE 5'...
