Tiller Best Rotary Tiller for 1950 Ford 8N Tractor
   / Best Rotary Tiller for 1950 Ford 8N Tractor #1
Rick230
Member
Covington, LA
Ford 8N 1950
I'm shopping for a rotary tiller for my 1950 Ford 8N tractor.
What size will work best?
What would be the best one for my tractor?
Thank you,
Rick230
   / Best Rotary Tiller for 1950 Ford 8N Tractor #2
I would think you could run 5' just fine, but how wide is your rear tire setup? You do want to cover your tracks. Ideally you have a little offset to it.
   / Best Rotary Tiller for 1950 Ford 8N Tractor #3
you'd think VERY wrong.
8n are geared tall. rotary tillers are not good fits with an N unless they have the very rare howard rotovator transmission installed. that or an everette trencher tranny.
N are good plow and disc machines.. very poor tillers.
I would not advise a tiller on anything under a 850.. ie.. 48 hp and 5spd. and really.. to get good performance.. a 10spd sos or a 6spd twin stick or 8 spd twin stick.
   / Best Rotary Tiller for 1950 Ford 8N Tractor #4
If the soil is prepped like I do, turned and disced in advance, that tractor should be able to do the fine prep with a 5' tiller. I had not thought of sod busting with it since I don't do that. Soundguy makes very good points in that regard. Tillers are not sod busting machines to me. I turn my veggie fields every year with a plow, disc them and fine prep with a tiller. Works for me.
The soil has been worked and is pretty loose. I use a walk behind tiller now. I also use a middle buster, and discs.
I'd like to be able to make a wider path than 18 inches.
The ground is very workable.
   / Best Rotary Tiller for 1950 Ford 8N Tractor #6
run shallow and run often.. will probably work.
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
