Heating a stuck grease zerk
/ Heating a stuck grease zerk #1
Vtnewbie
Northern Vermont
Branson 4720 with loader and backhoe
Something I've done a hundred times.... If the zerk won't take grease with a moderate amount of effort, hit it for a few seconds with the MAPP gas torch to loosen the pressure check ball and allow grease in. Worked like a charm the first 99 times :laughing:
Well the other day I was trying to grease the pivot on my backhoe, and the stuck zerk needed just a little more heat. Unfortunately that was just a little too much, and the check ball popped out with a report louder than a .22, but a little less than a .357. No idea where the little ball was launched to, but I was glad I hadn't had my eye directly over it while heating, which I'm sure I had done in the past. No injuries, but I did jump an inch or two off the ground. :laughing:
Sorry no video, and the only picture is of the boring old zerk after the explosion. IMG_0231.JPG
/ Heating a stuck grease zerk #2
Bet you tossed out your underwear!:eek:
/ Heating a stuck grease zerk #3
Yea think I'll stick to pull n clean or changing them lol. Glad your ok
/ Heating a stuck grease zerk #4
I usually have success by pushing in on the ball with a scratch awl or edge of a small screwdriver blade.
/ Heating a stuck grease zerk #5
Mate, thanks for posting. :thumbsup: I would never have thought of applying heat to a grease nipple IOT loosen the ball (JJZ said it best) but I reckon it's a 'shop trick' that was passed on by an old-hand.
The heating method sounds like it's in the category of "What Could Possibly Go Wrong?"
Lesson learnt for all of us (who read this thread, anyway).
/ Heating a stuck grease zerk #6
My preferred method is to unscrew the zerk and pump grease through it, then rescrew it back on. Or even better put a new $0.25 zerk in and throw old one away.
Yep, replacement is now my preferred method too. I even had a multi-pack of zerks sitting in the shed, and coulda/woulda/shoulda replaced the one that went boom instead of heating it in the first place. Heating was a shop trick passed along by an old friend, who still had both eyes, by the way.
/ Heating a stuck grease zerk #8
i used to pull them and soak in diesel.. or heat em. but with a 100 pack costing 4$ at harbor freight.. .. it's wastefull to do anything other than just repalce them.
/ Heating a stuck grease zerk #9
How have you found the HF zerks to hold up? Do they last? Have any bust off, requiring an easy out or something to remove? Just curious if you have experienced any quality issues before I start going cheap on these.
/ Heating a stuck grease zerk #10
It might have been interesting trying to explain that check ball "BB" lodged in you at the hospital.:eek:
/ Heating a stuck grease zerk #11
i sure have not repalced any twice. so i'd call that a 'no issue' answer.
In fact. the multi pack in the palstic box i got at HF for either 2.99 or 3.99 ( can't honestly recall ).. look EXACTLY like the same zerks sold inthe baggies at the auto stores in town.. and at tsc. they are likely ALL chinese made.. you just get to choose what price you want to pay. high price.. or low price. :) realize too.. that a retailer selling in bulk usually has better prices. i expect to pay more per unit if i buy a 10 pack and not a 100 pack. same quality etc.
my guess / opinion only.. ive done no 'real ' testing other than to simply repalce old zerks with new ones when needed and then use them ( pump with grease as needed. )
all threads have been correct.. and i doen't recall any leaking check balls... none broke during install.
/ Heating a stuck grease zerk #12
Ditto. Maybe there should be a new thread called "Parts From H.F. That Don't Suck".
/ Heating a stuck grease zerk #13
/ Heating a stuck grease zerk #14
I'd have to look it up but isn't it called "Tools" that don't suck? dunno....
/ Heating a stuck grease zerk #15
oh well..yeah.. it may be.. it took it to be a general thread on items sold at HF..
/ Heating a stuck grease zerk #16
What about replacing a zerk that has stripped the internal threads in an axle end? My friend pulled one off while greasing my axles this weekend; his grease gun zerk fitting was real tight, it pulled one off and now won't tighten back up.
I'll get one of those zerk kits from HF next time I'd down there.
Thanks,
/ Heating a stuck grease zerk #17
depending onthe axle size you have a couple options.
you could shrink the hole ID with some smacks open face by a hammer. or even stake it in with a pin punch.. or switch to a drive zerk. lastly.. you could drill out and go to the next size zerk. if the axle was broke down.. I might even braze it and retap it..e tc. all depends what / where..e tc..
/ Heating a stuck grease zerk #18
My friend pulled one off while greasing my axles this weekend; his grease gun zerk fitting was real tight, it pulled one off and now won't tighten back up.QUOTE]
I'd suggest that your good Mate loosen the tip of his grease gun for the future. It is adjustable. :2cents:
/ Heating a stuck grease zerk #19
/ Heating a stuck grease zerk #20
thanks... good enough recommendation for me.
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
(3) GOODYEAR 18.4-16.1 CLEATED TIRES (A63291)
(3) GOODYEAR...
