Mahindra 2810HST radiator just started leaking
   / Mahindra 2810HST radiator just started leaking #1
Shapachan
northeast
Mahindra 2810 hst
Any know if these are repairable? Found a dealer he want $600.00 plus shipping for a new one. Seems like a lot of money for a small radiator but being an old timer everything seems to cost crazy money.
thanks to anyone who can offer info
Len
   / Mahindra 2810HST radiator just started leaking #2
If it isn't a huge hole you can use ground black pepper. It really works. Just add gradually until the leak stops. I fixed the leak in my Thunderbird's heater core using about a 1/4 cup. It has held up for the last year.
With no pressure on the radiator its a steady drip, I have always been cautious about putting stuff in ... but SS don't go far these days. In the old days they could solder it up but you don't see shops doing that anymore all the cars are plastic
   / Mahindra 2810HST radiator just started leaking #4
If its not plastic it should be repairable. Don't use the pepper or any stop leak, it will be trouble down the road
   / Mahindra 2810HST radiator just started leaking #5
I don't see what harm can come from the pepper. If it works he has saved over $600.00. If it doesn't work, no damage will have been done.
   / Mahindra 2810HST radiator just started leaking #6
There are radiator repair shops that still do these types of repairs even on today's newer aluminum and plastic radiators. Locating them and getting slotted in their schedule is generally the most difficult part. They're not as widely available as the old radiator repair shops that did copper and brass repairs, so depending on where you are it might even require shipping your unit to them.
I personally don't like adding things to stop a leak, but if I did, I'd not use any form of "stop leak" additives to attempt the fix on my tractor. I would likely connect the radiator to some other pump/reservoir setup to run the stop leak through it just to keep that stuff out of my pump, thermostat, and the passages within my motor. I'd also recommend heating the fluid in your make-shift reservoir to simulate the heat of a running engine to ensure the product will work as described.
I've heard of several things you could add to a radiator to stop a leak ranging from eggs to black pepper, but if I was doing it myself I'd use a product made for such a thing, I just don't think I'd want it all throughout the system.
I have pulled the radiator out and proved it does leak, and not the hose connections. Its seeping out where the those fins meet the bottom collection area but cant pinpoint it. So going to see if I can find a local shop that has the expertise to fix it. I appreciate the input and if there are any dealers out there who want to put their 2 cents in please do. Failing all there is always radiator stop leak.
Thanks guys
PS my neighbor told he me he use to make a paste of sawdust and horse manure, he said it always fixed the leak and gave the motor a little extra kick when he needed it.
   / Mahindra 2810HST radiator just started leaking #8
If stopleak or pepper will stop that hole from leaking, what about the other holes in the block. Its his tractor he can do what he wants I was just offering friendly advice. I have changed radiators that have had stop leak in them and its a mess
   / Mahindra 2810HST radiator just started leaking #9
Yours is a valid concern. I have no idea how small the block holes are, but my guess is they are quite large. A small amount of pepper, or stop leak, added ever so gradually, isn't going to be able to plug a hole in a block; if my guess is correct. It is similar to finding the weakest link/leak, if you will.
Certainly there might be cases where someone put in too much black pepper. Moderation is key.
   / Mahindra 2810HST radiator just started leaking #10
It should be repairable if you find the right place. Having radiators fixed on cars was a common thing back in the 50-60's.... Good luck, Jerry.. :)
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 Chevrolet Tahoe SSV 4WD SUV (A50324)
2019 Chevrolet...
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
4 Drink Hog Waterer (A50515)
4 Drink Hog...
