Backhoe contaminated oil
   / contaminated oil #1
rogerm64
Port Clinton, Ohio
ford 4500
Posted by rogerm on April 18, 2013 at 05:13:04 from (76.189.26.181):
I checked the fluid in the trans and it was low so i took it up to the level. Just noticed today I used the hyd.oil for my 12000lb car lift its
ISA 46 fluid Not my trans hydro oil It has been ran with this oil in it so it is all through the system. what is the proper steps in flushing this all out.
Have a 72 ford 4500 backhoe 4 speed auto reversing trans
I may have posted twice if so I am sorry!
once again thanks for any input
   / contaminated oil #2
if you jusrt added a lil junk hydro oil to the system.. it's ok
if it's alot. just drain and refill with utf and don't worry too much...
   / contaminated oil #3
I have a Boomer 30. having problems with the loader locking up when lifting or dropping if open valve completely. Is there a safety valve or adjustment to valve body? Can't find any info. any ideas? It is a tl240 loader
   / contaminated oil #4
First thing to do is to disconnect and reseat your quick connects to the loader. If that doesn't fix the problem, I suggest your start your own thread. It is extremely hard to try to post in a thread where multiple people post different problems. It''s not good for you and it's not showing courtesy to the original poster.
   / contaminated oil #5
I made that same mistake when I first joined too. Start a Thread as Jinman said.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A56435)
2017 Cadillac...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
