Questions about a tank for my new Mig Welder...
   / Questions about a tank for my new Mig Welder... #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I have been using flux core in my new to me mig welder and have been looking for an Oxy / Argon tank...I found this one on Craigs List..
CO2 Welding Paintball Tank
My question is can I use straight oxygen until the tank is empty( don't want it to blow up ) and then when I take it to get it filled will they put Argon in this tank ? I ask since I am wondering if there are certain tanks for oxy and then oxy /argon mix....
Thanks in advance for any advice
   / Questions about a tank for my new Mig Welder... #2
??? The seller says that "It is full of CO2" not O2.
Aaron Z
   / Questions about a tank for my new Mig Welder... #3
Bob you can use the CO2 in Mig welding, I am not sure what connector that tank has on it, it could be CGA 320 and a normal MIG mix tank would have CGA 580. what regulator do you have? is it a CGA 580 fitting.? You normally don't use pure Argon for MIG, you normally use Mig mix. which is 75% Argon and 25% CO2. Co2 gives more splatter, and slightly deeper penetration. A lot of guys do use it instead of Mig Mix because it is cheaper. Of course you don't use O2 or oxygen at all.. wow that would be dangerous.:shocked: and not at all effective. The whole idea of a shielding gas is to shield the weld from oxygen and nitrogen in the air by displacing it with the inert gas. Of CO2 is not exactly inert. You normally use Pure Argon for TIG welding. See if your regulator and the cylinder fitting are compatible. Also I think your flow meter reading are different for CO2 vs Mig mix.
Aaron Z
So you can tell I know nothing about this welding or welding with gas....I fixed my son's rake...that went well...but I just don't want to blow myself up....Thanks...I will be careful with the use of Co2 vs 02...;)
James ...I will check my regulator and see if it has any ID of any kind on it....It would help if I had a clue about what I was doing...LOL
When I bought the welder it did not include the tank...but I got the hose and regulator etc...other small parts and wire...the seller said to just look for a tank...yeah, easier said than done around here...they are hard to find even going to buy a new one...which I'd rather not do.. I will call the seller and if he still has it for sale I will see if it fits my welder regulator....
I just wanted to use up what he had in the tank before finding a place to put the argon/oxy mix in there...( hope I got that Oxy right ) :)
Thank you guys for so much help...
   / Questions about a tank for my new Mig Welder... #5
I just wanted to use up what he had in the tank before finding a place to put the argon/oxy mix in there...( hope I got that Oxy right)
No not argon oxy mix.. Argon CO2 mix.. called Mig Mix by many. a mixture of argon and carbon dioxide.. NOT oxygen.. Oxygen in Mig welding has NO place.. Big NO NO... go Boom.. catch fire burn your whiskers... :shocked:
   / Questions about a tank for my new Mig Welder... #6
No problem, gotta start from somewhere
Its Argon/CO2, not Oxygen (the idea behind the "Shielding Gas" is to SHIELD your weld FROM Oxygen) but otherwise if the regulator fits, you should be good to go.
Aaron Z
   / Questions about a tank for my new Mig Welder... #7
here are some pictures, maybe this can help
here is a drawing of a CGA 580 fitting, the female Tank is on the left and the fitting is on the right. cga580.jpg
The here is a CGA 580 regulator/flowmeter, like you would buy on ebay.. notice the Male threads and rounded sealing face.small CGA 580 flowmeter.JPG
here is both a CGA320 and a CGA580 fittings that would mate up to thier respective tanks.. Notice the CGA320 fitting is female and the tank would be male.CGA 320 CGA580.jpg
Finally here is a CGA320 regulator/flowmeterCGA320 reg flowmeter.JPG
Hopefully you have a CGA580 regulator/flowmeter and that tank is CGA580, but I cant see it well enough to know. All I am saying it would not be a good deal to buy a tank that does not match your regulator..
James K0UA
   / Questions about a tank for my new Mig Welder... #8
Actually 98% Argon, and 2% oxygen is a very good mix for spray transfer welding. You still need a machine that can get into the high 20s for volts though.
   / Questions about a tank for my new Mig Welder... #9
I don't believe Bob is going to be doing a lot of spray transfer with his little 110 volt Mig. though:)
   / Questions about a tank for my new Mig Welder... #10
Oh, I didn't see that part:eek:. Lot of guys come onto the welding forums thinking they're going to build bridges with their 110-volt Mig welder.:D
:thumbsup: Bob does not know what Spray transfer even is...LOL...I really can't say enough how much I appreciate you James and all the guys here for helping me...I truly wouldn't have even bought this welder had it not been for the encouragement..and in practicing I have found out I really enjoy it and the challenge to get better....Hey , I fixed my son's rake...brag...brag...but it save him $20 to buy a new one....Thanks again all...;)
   / Questions about a tank for my new Mig Welder... #12
I'm sure I won't live long enough to pay for all my welding equipment in repairs.
   / Questions about a tank for my new Mig Welder... #13
It does give one a good feeling when you repair something or build something that you just would not have been able to do without your welder.
   / Questions about a tank for my new Mig Welder... #14
Bob, for simple repairs on things like rakes, why not use fluxcore wire instead of fiddling with MIG gases. The welds are not quite as pretty but they are equally strong and you don't need no stinking gases. Makes for much easier simple repairs outside for example. Any MIG welder can run fluxcore, just pick up a 2lb spool of 0.035 for starters and put it on the machine just as you would MIG wire. No gas connection needed (the fluxcore wire is hollow with flux inside which burns and creates a shielding gas just like with stick welding). Very simple. Easy peasy lemon squeezy as my daughter would say.
here is a drawing of a CGA 580 fitting, the female Tank is on the left and the fitting is on the right.View attachment 338246
The here is a CGA 580 regulator/flowmeter, like you would buy on ebay.. notice the Male threads and rounded sealing face.View attachment 338247
here is both a CGA320 and a CGA580 fittings that would mate up to thier respective tanks.. Notice the CGA320 fitting is female and the tank would be male.View attachment 338248
Finally here is a CGA320 regulator/flowmeterView attachment 338249
James K0UA
I just checked James and based on the pictures you sent ...I do have the CGA580 - It has tow guages on it with a dial in the middle the outlet on the back is male and so is the one on the side..the one on the back goes to the tank and th side must be for the plastic gas line which I can't find now...darn it...I know I had it and I just looked in my shop and did not see it so ...I hope that is not hard to find...I remember having it ...it was a small dia. clear plastic hose rolled up...geeez. anyway thanks for the pics...now I can call him and know what I'm talking about ...a little...LOL
   / Questions about a tank for my new Mig Welder... #16
The little hose is not critical, should be easy to find another. Since you are already flux-core welding, I assume you want to try MIG for prettier welds right? and you do know that welding outside with MIG is problematic right? It doesn't take much wind to blow away the shielding gas, whereas your flux-core is good to go outside just like stick.
Doc, I have a bush hog that has two pretty serious fractures...I hit a pretty big log and it cracked the deck on top on each side about 1/8 " wide by 6" long splits on each side at the front ...top of the bush hog deck...it is about 3/8 " thick...so I thought for this project I may need the shielding gas for deeper penetration at least that is what I have seen on a few You Tube videos....other than that ...I agree...I would rather not mess with gas but I am thinking....never know what repair may be needed and if the penetration is greater with gas...why not.....just as long as I don't blow myself up....:confused3:
Mainly for the big repair of the bush hog...but if you don't think I would get enough extra penetration with shielding gas then I won't even bother with it ...like Doc is suggesting...I mean for the welding I will do it is fixing rakes and rough stuff...I don't foresee being an artist and creating sculpture...LOL...Let me know what you all think...if I don't need the gas...I'd just as soon skip it...?????
   / Questions about a tank for my new Mig Welder... #19
Don't believe everything you read / see on the Internet! Joint prep is very important to having a good weld.;)
I've only played with one 110-volt Mig machine, so I really don't have any experience with them. But I have lots of experience with flux core self shielded wire. I think you would be surprise how many buildings, and bridges are welded with flux core self shielded wire.
Here are a couple of my flux core welds. I don't think they look to bad, besides isn't that what paint is for?:laughing:
   / Questions about a tank for my new Mig Welder... #20
Bob, if I was wanting to weld on the bush hog, I would be using your flux core. The metal is thick and dirty. Lets see what the guys with more MIG experience have to say.
Solid Wire Versus Flux Cored Wire: When to Use Them and Why
Comparing the advantages of MIG and Flux Cored.
Gas metal arc welding (GMAW) and flux cored arc welding (FCAW) possess different characteristics that welding operators must evaluate when selecting them for welding applications. To achieve the best results, consider the following factors: thickness of the material, proper shielding gas, wire feed speed and voltage settings, location of the work site and weld appearance. There is no "one-size-fits-all" welding solution and all of the above variables will affect the operator's decision to use solid or flux cored wire. This article will help the novice or occasional welding operators such as farmers, ranchers, motorsports enthusiasts and home hobbyists, understand the basics of solid and flux cored wire and how to maximize the advantages of each.
Solid Wire/MIG Basics
MIG power sources use a continuous solid wire electrode for filler metal and require a shielding gas delivered from a pressurized gas bottle. Mild steel solid wires are usually plated with copper to prevent oxidation, aid in electrical conductivity and help increase the life of the welding contact tip. The shielding gas protects the molten weld pool from contaminants present in the surrounding atmosphere. The most common shielding gas combination is 75 percent Argon and 25 percent CO2. While using solid wire outdoors, the operator should use caution and prevent any wind from blowing the shielding gas coverage away from the welding arc. Windshields may need to be used.
Flux Cored Wire Basics
There are two types of flux cored wires: gas shielded and self shielded. Gas shielded flux cored wires require external shielding gas and the slag is easy to remove. The operator may want to consider using gas shielded flux cored wires when welding on thicker metals or in out-of-position applications. Gas shielded flux cored wires have a flux coating that solidifies more quickly than the molten weld material. As a result, it creates a "shelf" to hold the molten pool when welding overhead or vertically up. Self shielding flux cored wire does not require external shielding gas; the weld pool is protected by gas generated when flux from the wire is burned. As a result, self shielding flux cored wire is more portable because it does not require an external gas tank.
WHAT TO CONSIDER WHEN CHOOSING SOLID OR FLUX CORED WIRE
Appearance
Many welding operators believe that weld appearance is an important factor. When you are working on materials less than 3/16 inches down to thin sheet metal (24 ga.), solid wire will produce a clean looking weld. For example, a short circuit transfer with .030-inch solid wire set at 18-19 volts with 160-170 amps and using 75 percent Argon and 25 percent CO2 shielding gas will usually produce little spatter, create a smaller heat affected area and reduce chances of burn-through. As a result, many automotive enthusiasts who specialize in bodywork or those who work with thinner applications prefer solid wire in their operations.
The welder must also consider the location of the work site when choosing between solid and flux cored wire. There are certain environments such as windy locations, where solid wire or gas shielded flux cored wire cannot be used; exposing the shielding gas to wind can compromise the weld integrity. Typically the loss of shielding gas will produce porosity visible in the weld bead.
On the other hand, self shielded flux cored wire is ideal for welding outdoors or in windy conditions. The operator does not have to set up windshields to protect the shielding gases from being blown away because the shielding gas is generated from the burning flux. Since self shielded flux cored wire does not require external shielding gas, it is also more portable than solid wire. This portability is ideal in agricultural applications where field equipment can break down far from the shop. If you are welding thicker metals (16 ga. and above), self shielded flux cored wire also provides excellent penetration.
Thickness, Type of Application and Parameter Settings
Many novice operators attempt to use "a-one-size-fits-all" wire and shielding gas combination for multiple applications. The most common wire and gas combinations (for solid wire) are .035-inch diameter wire used with a 75 percent Argon and 25 percent CO2 shielding gas. When welding thicker material, however, consideration needs to be given to welding power source output, as well as welding wire diameter. If the .035-inch wire is selected for thicker materials, and the power source is one that is plugged into a 115-volt circuit, the resulting amperage output may not be sufficient to make quality welds. The chance of "cold lap" or "lack of fusion" may increase.
Attempting to use too small of a solid wire for thicker applications (such as on A-frames of an automobile), increases the chance of lower penetration in the root, and could require more than one welding pass. Misapplication of the solid wire (even though strong enough) may also not provide adequate penetration on thicker material.
Although more expensive than solid wire, flux cored wire could help you gain productivity. Flux cored wire typically has the ability to handle the welding of dirtier materials that may have higher levels of rust, mill scale, or oil. Although cleaning is always the proper method of preparing the steel, flux cored wires contain de-oxidizing elements that trap these contaminants in the weld pool and hold them in the slag coverage typically preventing the associated weld problems found when welding "dirtier" steels. Flux cored wire also increases penetration on the side walls and offers the advantage of better deposition rates (the amount of weld metal deposited in a given time period, measured in pounds per hour) when compared to solid wire. Although the operator is initially spending more on materials for flux cored wire, the savings are realized in the decreased production time.
Which is better, solid wire or flux cored wire?
Neither wire is superior over the other. They simply have different properties, which work better on certain applications. As far as performance is concerned, both types of wire produce sound welds with good weld bead appearances when applied correctly and used within the proper parameter settings. Solid wire provides deep penetration in the root and usually has little spatter. Flux cored wire has a larger ball type transfer and produces low spatter levels. In addition, flux cored wire produces a rounder penetration profile with excellent sidewall fusion.
As far as user appeal, both solid wire and flux cored wire are relatively easy to use and are ideal for novice and occasional welders working in automotive, farming and home hobby applications. Operator appeal on solid wire may be better on thinner applications because there is no slag to remove; it is ready to paint; and the weld beads may be more aesthetically pleasing.
Conclusion
The most important thing to remember is not to fall into the "one-size-fits-all" mindset. Solid wire, self shielded flux cored wire and gas shielded flux cored wire all work well provided they are applied correctly. The type of wire you choose will be contingent upon the location of the work site, thickness of the application, proper shielding gas combination and the type of equipment available. The operator should always clean the work piece prior to welding to ensure optimum weld quality and prevent impurities from becoming trapped in the weld bead. In order to achieve the best possible results, the operator must be willing to make adjustments based on the worksite variables and consider having both solid and flux cored wire available.
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
