Relay switch seems to keep Failing
   / Relay switch seems to keep Failing #31
Thanks for helping out guys. I have been outside all afternoon washing one of the decks to get it ready for painting. And I am bushed.
Here is some more diagram.
You swapped the relay, same results, relay should be good. Use kOua's diagram for reference.
If you have no test equiptment, make a short jumper wire and jump the green and red, it should crank. This would eliminate the starter and wiring to it.
If you have a test light, check for voltage at the pink wire, when turning the switch to start. No voltage = bad ignition switch or wiring, or fuse.
If these are all ok, then it may be a safety nuetral switch, pto switch, etc. Does your N light when the key is on? Check this first.
Dave
   / Relay switch seems to keep Failing #32
Dave
There is NO neutral safety per se, but there is a range selector lockout for anything other than neutral between L,M,H. Similar but somewhat different. It keeps the key from allowing the starter to crank.
   / Relay switch seems to keep Failing #33
It is actually a potentiometer. Believe it or not.
FIXED!! It turns out it was a bad Engine stop Relay. All I had to do was swap this out and its starting fine! Thanks for all the advice everyone! :thumbsup:
   / Relay switch seems to keep Failing #35
See...that wasn't so bad. LOL! You learned something about your tractor as well. Glad it's fixed, now go dig something! :laughing:
   / Relay switch seems to keep Failing #36
All's well that ends well.:laughing:
   / Relay switch seems to keep Failing #37
Which leaves me with a confused look on my face, because I fail to see how a bad engine stop solenoid would keep the tractor from cranking. It could keep the tractor from starting but not keep the tractor from cranking. And all this time I thought the problem was the tractor would not crank. I am beginning to believe this remote diagnostics is not all it is cracked up to be:)
James K0UA
   / Relay switch seems to keep Failing #38
Which leaves me with a confused look on my face, because I fail to she how a bad engine stop solenoid would keep the tractor from cranking. It could keep the tractor from starting but not keep the tractor from cranking. And all this time I thought the problem was the tractor would not crank. I am beginning to believe this remote diagnostics is not all it is cracked up to be:)
James K0UA
You still do better than others.:cool: Good Job All!
Just so you know it was the engine stop relay switch that was bad, the whole time. I thought it was the engine start relay switch but it was really the relay on the far right as your looking at the tractor. Maybe if it goes bad there's some safety feature that prevents the tractor from starting. Thanks again to everyone that helped! ;)
   / Relay switch seems to keep Failing #40
Speaking of ignitions switches. Does anyone know where one can be ordered? I have a '06 CK25 HST that I'm positive the ignition switch is going bad. I'd just as soon replace it if I have to take it out. TIA.
2013 International Derrick Digger Truck (A55973)
2013 International...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55315)
2020 John Deere...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
