Dirt screed
/ Dirt screed #1
Rio_Grande
I need to build a dirt screed. I understand the basics, but I need some insight on the vibration mechanism and on the angle to set the screed at.
Any help would be great!
/ Dirt screed #2
I am on the look out for a vibratory shaker used for screens on oil drilling rigs. These are about 4 to 5' long and have an enclosed eccentric shaft which spins and sets up the vibration. My plan is to hook this up to my rock bucket and run it with a hydraulic motor using the third fel circuit. Have to build the suspension mounting for the bucket also.
If you wan't a vibrating screed to use stationary you could use an electric motor to run it. I would prefer to make the screed angle adjustable as there isn't a perfect setting as it is dependent on your particular soil and rocks. A little trial and error will help you find the right pitch that works for you. Something like a trailer screw jack would work well for this adjustment.
/ Dirt screed #4
They also make 12 volt vibratory shakers for dump truck boxes to rattle out the dirt that might be worth looking at.
/ Dirt screed #5
I don't think a 12 volt vibrator from a dump truck would be good for continuous duty. Years ago I saw a homemade screen on a much bigger scale. It had it's own power plant with a hyd. motor for the shaker. The shaker sat on 4 big coil springs from car or truck. The hyd. motor was coupled to a shaft that ran across the shaker under the screen material. It used a weight on one side of the shaft to throw it out of balance and it could be adjusted by the hyd. flow or engine RPM. I think they experimented with how much weight to use and ended up using a smaller weight than they original thought they'd need.
/ Dirt screed
How much of a cam would I need for a 4x 8 bed?
/ Dirt screed #8
That's probably true as I hadn't thought about continuous duty. I was thinking more along the line if someone just wanting a load now and then.
The big ones we had at the quarrys and gravel pits were as you described ---
QUOTE["The shaker sat on 4 big coil springs from car or truck. The hyd. motor was coupled to a shaft that ran across the shaker under the screen material. It used a weight on one side of the shaft to throw it out of balance and it could be adjusted by the hyd. flow or engine RPM"]QUOTE
I never remember a problem with the shakers as long as they're greased. The major problem is screens wearing thin, then big rocks blowing holes through them and occasionally they would break a spring.
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
