super55
- Joined
- Jan 27, 2012
- Messages
- 960
- Location
- Great North of Michigan
- Tractor
- Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
I have an old Mott 60 flail mower that I had picked up off craigslist that shudders and has excessive vibration whenever operating at PTO RPMS on the tractor.
It originally had knives that were too large for it and were slapping against the housing but I have since replaced all of them with new correct size finish blades. Lifted it up on 3 pt with a couple of jackstands and crawled underneath to inspect. Not slapping the housing anymore, the bearings on the shaft seem tight and as far as I can tell the main shaft does not appear to be bent.
It doesn't do it all the time but seems to occur more often in heavy grass. I took the safety cover off where the drive belt is and when it really starts to shudder the spring loaded tension pulley is really bouncing back and forth. Is it possible that the lack of pressure on the tension pulley is causing the flail to slip and grab at a rapid pace causing the shudder? Its the only thing immediately that I can think of besides grass being wrapped around the flail shaft is putting it out of balance.
Anybody else have any similar experiences and/or remedies? I'm about to concede defeat and swallow my pride and admit that I may have gotten hosed on this purchase.
