Got it
/ Got it #1
landedakioti
Gold Member
vermont
kubota L4060 hst
Got the tractor back. Started up fine . Loaded upon the trailer brought it home started backing it off the trailer now it has a squeal in revers. Weird . Took for a ride down the road feels different going down the road then before but in a good way. Then I moved some wood I split in the bucket a it didn't die out. So that's good. But after I did that I parked it and did a walk around and two loader pins had the bolts that hold the pins are gone so I called the dealer mailing some out . It has been a long day .
/ Got it #2
I kept losing loader clips. If the pins come out and you don't notice you can break things in a heart beat. I decided to wired my pins on so they can't come off. Been good now for 5 years or so since doing that. Hope your reverse squeal goes away and you now begin to have good service from your tractor. Sunny skies ahead!
/ Got it #3
Glad to hear you have your tractor home. I hope they did a better job of repairing your tractor than they did prepping mine. I am disappointed in their workmanship.
/ Got it
What up with yours? I still have the squeal in revers. I haven't tried digging with it I hope to try that next weekend.
/ Got it
I also asked if I could have a write up for the work they said I had to wait until they get a copy from kioti which I find weird. That I have to wait for it.
/ Got it #7
I found several issues with the prep/install work they did. I am going to give them a chance to correct them before I share what they did.
There is a long thread about the squeal in reverse issue, have you read it yet?
/ Got it #8
Have them include the free kit to stop the HST squeel. Takes about 20 minutes to install if you have a big wrench.
/ Got it
The squeal is gone. But after two days at the house moving some logs it won't start again. And I'm not paying again to transport again. Now it time to file paper work .
/ Got it #10
Wow. Time for a new tractor.
/ Got it
I talk to the dealer that worked on it they are coming out to look at it. Wow they are going out of there way to help get this issue fixed but I just have my doubts this tractor will run right I feel like it a lemon and I think kioti should exchange it got another one . Let them have the one that won't run.
/ Got it #12
Glad to see that Kioti has stepped up for you Nathan. Hope its something simple this time.
/ Got it #13
So file papers; no wait, demand new tractor - tick tock, the saga continues......:confused3:
/ Got it #14
If the dealership that is doing the work has to keep coming out to fix it, they can end up being your best friend.. Keep them on your good side.
/ Got it
Well them came yesterday and replace something's they got here just as I was leaving to pick up my daughter. We shall see if it stays running. Very disappointed in kioti. Not disappointed in the dealer here in Maine going out of there way to help.
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
Big John Semi Trailer (A65640)
Big John Semi...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
Bale Spear (A66408)
Bale Spear (A66408)
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
